Results 1 to 7 of 7
Thread: Feeding a Wired Router from a Hotspot?
    Jan 2008
    I have 3 computers in my van. I want to install a high-gain 802 antenna, but since I have 3 computers, I do not want to have to install 3 antennas. I would actually like to have all of the computers wired to a router, if only I could feed that router internet access from a Wi-Fi spot.
    Is something like that even possible? Can I somehow use 1 nice antenna on the van to feed 3 computers somehow?
    Any advice on how to do this would be appriciated.
    Vaughn
    Newbie mirciu's Avatar
    Apr 2007
    well, you could do it with dd-wrt firmware. get linksys wrt54g, flash it with the dd-wrt (linux kernel) and you will have a myriad of options possibilities. As long as the hotspot is not using any protection you can connect to them with ease. Also this firmware has some options for increasing the gain on the antennas...
    Good luck
    Low Bitrate IssaquahWA1979's Avatar
    Oct 2009
    Issaquah Washington
    this is very doable and as stated above is easiest with DDWRT, you could also do it with Tomatoe if you do not have a router that can handle DDWRT such as the newer model Linksys with less memory...
    Custom Built Intel D510MO, 2GB RAM, M4-ATX, Elios 15" TS on custom mount.
    System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
    I can provide Custom fabrication for mounts or installation please contact me. CNC Machining and Powder Coating
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You want a wireless bridge. You plug your 3 computers into the bridge, then use the WiFi in the bridge to connect to a WiFi network. All computers have access to the net over the bridge.
    If you will use an external antenna, make sure you get a bridge with the ability to connect an external cable to it.
    As stated, DDWRT will do this but you can also purchase this type of solution. Google "Wifi bridge" to find options.
    Want to:
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    [media]http://www.youtube.com/watch?v=S0zt4opqL18[/media]
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    "It's gone. It just disappeared. So I bought a WiFi extender...."
    Want to:
    Aug 2007
  1. Wireless router to wireless router wirelessly
    By Jackso in forum Wireless Communications
    Last Post: 02-22-2010, 12:30 PM
  2. Replies: 9
    Last Post: 05-27-2008, 02:11 AM
  3. Mobile Hotspot Setup - Please Critique
    By coredump in forum Newbie
    Last Post: 05-26-2008, 10:20 AM
  4. Wireless G - Wire'd Network Problems (Remote Desktop)
    By nFiniteTuning in forum Wireless Communications
    Last Post: 01-01-2005, 07:34 PM
  5. FS: Craftsman Router, Router Table, Router Bits
    By tbird2340 in forum Classified Archive
    Last Post: 10-19-2004, 07:50 AM
