Results 1 to 10 of 11
Thread: Connecting two phone over bluetooth. I there possible?
    Newbie burleanu's Avatar
    Mar 2009
    Romania - Cluj
    Question Connecting two phone over bluetooth. I there possible?
    Does anybody had succesed to connect two phone (headset connection) to the car pc on the same time.
    For example if I have two different phone (one on one GSM network and the other on other network) is there any posibility to make the computer (eg. CarPc) to act as multi-point headset or something similar to be able to receive cals from the two phones,ok not in the same time, but to able to answer from the same pc for example. To not every time change the default connection.
    Does you know about some tricks to do this thing.
    I've search on the internet and the only thing found is only some headsets that are capable to do that but for PC software I've get nothing.
    Cheers!
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    theres half a dozen threads with the exact same question
    Low Bitrate majasticmoose's Avatar
    Dec 2009
    Mar 2009
    Romania - Cluj
    Ok
    Thanks for reading and reply but this is not my question.
    I had "pair" the both phone with the car pc but only one is working all the time, the other phone is working if i disconnect the "first" one.
    I was asking if is possible to make both working without disconnecting the first phone connected.
    For example:
    Connect "phone no.1" to carpc,
    Connect "phone no. 2" to carpc,
    Receve calls on the phones and automatic answer the phone who is ringing. For eg. "phone no 1" calling and push answer and "talk". "Phone no 2" ringing, push answer and talk, "phone no 1" ringing again and push talk and answer.....and so on, no mater what phone is ringing. Without being necessary to disconnect one phone and talk on the other one, because now is working only if I disconnect one of the phone is ringing on the other one.
    Please show me the treads were is explain because I did not find something like that to be able to to what I need.
    I've found only device (head sets with multipairing ) that are capable to do that, but I thing is much more nicer to be able to use carpc and not having to wear all the time a headset.
    Respects!
    Mar 2009
    Romania - Cluj
    nobody know?
    Please help.
    Cheers!
    Dec 2009
    Try Google Voice and have your phones auto disconnect.
    Andrew
    Mar 2009
    Romania - Cluj
    thanks man,
    but something else I can't find? Because is just for US only and it also require internet connection, for all time for calls, plus that it require invite.
    I'm thinking for something more easy. is there any trick to full the PC to connect to both phone in the same time and to pick calls when they arrive.
    Cheers!
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Currently....no
    Maximum Bitrate PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Your next question should be "will windows support 2 BT USB dongles and allow them to coexist in windows?"
    If the answer is yes, you may be onto something then. I have no clue if it will work, but maybe somebody has tried it.
    Newbie rogue212005's Avatar
    Apr 2007
    McPherson, Kansas, United States
    Quote Originally Posted by PhilG View Post
    Actually the answer is yes, I tried this once, had my phone paired to the PC with one dongle, and my headset paired to the other and was able to hear and talk through the headset to the pc to the phone, I did this for kicks, and to prove to a friend it could be done. Now the question I have is what software is there that will communicate with two dongles simultaneously and allow the interaction your looking for.
    Now on the other hand my bluetooth device in my CarPc supports up to 8 simultaneous connections at once, but then again the software issue comes up.
    Can't think of a single cool thing to type here........
    Progress:
    Hardware:
    Parts Acquired: 90%
    Configured: 50%
    Software: Not Even close!!!! Looking for a good phone software solution
    Fabrication and Install
    Screen Mounting Figured Out!
  1. bluetooth woes
    By gentoocar in forum Linux
    Last Post: 12-12-2009, 03:05 PM
  2. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 09:29 PM
