Results 1 to 7 of 7
Thread: Iphone tethering keeps getting disabled
    Constant Bitrate Goddy's Avatar
    Dec 2004
    Netherlands
    Hi,
    Iphone tethering via USB just really works like a charm. Just connect the Iphone via usb and internet is available without having to dial or start any tools manually. My Iphone carkit is hooked up via USB so this is the perfect way.
    There is just one problem left. When I'm having a call for more than about 2 minutes, the tethering function gets disabled. In that case I have to manually switch tethering back on. Is there some kind of way that this tethering option will not be disabled during a call?
    I have found an easier way, whic is called SBSettings. With this tool you can quickly enable/disable tethering, but also 3g/wifi/bluetooth etc. This helps me prevending from going through all the menus, but I just don't like it to enable it manually after a call.
    Anyone?
    Dec 2004
    Netherlands
    So I assume no one has this problem or no one has a solution?
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    I believe if you search through Cydia or Rock (or whatever program you use) there is a "program" that will automatically re-enable tethering for you. I just don't remember what it's called... Have you asked around on the iPhone sites/chat rooms?
    After a 2 year break, I'm back! There are so many new and familiar faces here!
    New vehicle, new ideas!
    Chryssi - The Changeling CarPC Project
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    mywi? It does enable tethering control and more, but I'm not sure it's going to solve your issue. There's a trial, so you can test it, which is great (cydia apps don't allow trials, AFAIK).
    May 2008
    Quote Originally Posted by RipplingHurst View Post
    Actually, some Cydia apps have a built in trial. Then they make you go into Safari and buy them. But most of then are
    Dec 2004
    Netherlands
    I searched through Cydia but couldn't find any tool like it, to automatically re-enable tethering after a call. Guess I'll be ok with SBsettings
    Low Bitrate capcadetjc's Avatar
    May 2008
    Lubbock, TX
    Yeah I used to have that problem but I havnt had it lately. Theres an app in the Rock store that will make your iphone a router and help with the USB tethering. I dont think its cheap but if its what you need you may have to pay for it.
    What Im trying to do now is get my tethering to work with Bluetooth. Im using XP and just cant figure out how to get the computer to use it as a modem. If anyone has an idea that would be great.
    My 2007 Jeep Wrangler Worklog
  1. Iphone tethering
    By scatebase in forum iPhone and iOS
    Last Post: 04-02-2010, 02:36 AM
  2. iPhone now with tethering for mobile access
    By parksgm in forum StreetDeck
    Last Post: 08-08-2008, 08:11 PM
