Results 1 to 6 of 6
Thread: Bluetooth Widcomm software and GPS issues
    Newbie Scratch's Avatar
    Nov 2009
    North Carolina
    Question Bluetooth Widcomm software and GPS issues
    I just bought a Bluetooth dongle (iogear GBU421w6) and it runs the broadcom WIDCOMM software. I initially installed the software that came with the BT on my XP sp3 pc, but uninstalled from the control panel and downloaded the software from the broadcom website. The problem is that with the software installed Garmin mobile PC no longer has a signal. When I uninstall the BT software I get a GPS signal. I have HD radio on COM1 and GPS BU353 on COM2 and I think XM on COM3(another issue I am working on). Solving this hopefully will allow the GPS to work with the BT and allow me to pair my phone.
    What should I be looking for, is it a conflict on the comport?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    It could be that the BT dongle is reserving a com port and shifting things around. When the BT software is installed, are you getting messages from the GPS unit on COM2? Open it in hyperterminal (Or any other terminal of your choice at 4800 baud and check. If you are not, then likely it's shuffling com ports around.
    RevFE
    My Shop
    Nov 2009
    North Carolina
    Thanks malcom for the response. I ran a serial port program on com2. When I open Garmin is see in the log com 2 opened by Que.exe then followed by com 2 closed. This repeats over and over. A utility that came with Garmin called GPS information when I scan the ports it returns 3 com's and on 1 & 2 no GPS receiver and on 3 no device. Under Device manager this is what is under the ports. Bluetooth comm (COM3), Communication port (COM1), MJS XM interface (COM2), and Prolific USB to Serial Comm (COM3).
    Not sure what to do with this info. I guess I need to uninstall and see where everything when GPS is working.
    Update:
    Uninstalled bluetooth software, GPS works. Device manager shows the same as above, just the bluetooth comm is no longer there and the GPS is showing on COM3.
    How do I install the bluetooth software and force a different comport or change the comports?
    Jun 2004
    Westminster, MD
    I'm not near a windows computer so I can't walk you through it, but in device manager, if you right click on the properties of your bluetooth COM port (or the GPS one), you should be able to change which COM port it's using. Two drivers on the same COM port would certainly cause issues, switch one to say, COM4 and try again.
    RevFE
    My Shop
    Nov 2009
    North Carolina
    I was able to Change gps to com4 and that fixed that issue. Now I have to figure why my iPhone will not pair even though the bt and phone see each other
    Jun 2004
    Westminster, MD
    Glad you for the serial port issue fixed. Can't help with the iphone thing though, good luck!
    RevFE
    My Shop
  1. Please Help! Widcomm 4 Bluetooth problems...
    By shmartyn in forum Wireless Communications
    Last Post: 07-28-2007, 06:09 PM
  2. Vista, Bluetooth widcomm. drivers
    By EL CAMINO in forum Wireless Communications
    Last Post: 03-21-2007, 04:40 AM
  3. Widcomm Bluetooth - stop asking for password
    By birdie in forum Software & Software Development
    Last Post: 03-13-2007, 12:33 PM
  4. widcomm bluetooth problem
    By Bobble in forum Wireless Communications
    Last Post: 06-30-2006, 12:55 PM
  5. Widcomm driver for Belkin bluetooth
    By F350 in forum PhoneControl
    Last Post: 08-25-2005, 05:25 AM
