Page 9 of 22 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 213
Thread: Sprint Wireless Internet hack
  1. #81
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    i concur with everyone who said you cant use a sprint vision phone as a modem for a pc, whether at home or in a car
    i called sprint to check for myself
    sprint vision unlimited allows for unlimited web access on your phone ONLY...
    you get charged use for modem and if they find out they will terminate your contract
    i had my CS check with his super and he confirmed, w/the part about termination & strong recommendations against it
    [4Runna]
    next - wifi
  2. #82
    Dec 2004
    Sprint Connection Speed
    My sprint phone connects up with the usb to my laptop at like 230 kbps. I use it quite a bit for emergency's or to get me email when i'm traveling, and I havnt been repremanded by sprint yet.
  3. #83
    Maximum Bitrate clean customs's Avatar
    Jan 2005
    Houston
    Quote Originally Posted by nsmoller
    I just left the sprint store, and got almost the same answer. I went in looking for a data cable, and they told me they no longer sell them or will make them again. So I asked him if you are telling me that data connection on the bottom of this phone and every other phone you sell is useless? And he said yes. I have tried already with a bluetooth sprint phone and it worked, but returned the phone because it didn't work with phone control.
    Anyway, he told me they may not catch it now, but they are tracking it and will eventually charge you within a few months at 2 cents per megabyte.
    He told me the reason why is because they are only pushing there laptop cards and the monthly charge for that. And he told me that I could buy a conversion from CompUSA from a card to either a USB or something else I can use on a real computer. He seemed to know exactly what he was talking about, so watch your usage if your not already. I don't know exactly how well they track it or watch it, or plan to charge you.
    good luck
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
  4. #84
    Nov 2004
    Quote Originally Posted by icet
    My new phone is sanyo 8200, free at bestbuy right now...
    work pretty good...got it connected without using any software at all..
    just use winxp dial up config...that is it..
    connect at 1150kps and download rate range from 11-16 kb/s
    hope this help...
    icet
    can I get some more info on how to set this up with winxp dial up. I also have a Sanyo 8200. Not having to install any 3rd party software sounds like the way I want to go. I will be bidding on a cable on ebay now. any help would be appreciated.
    Edit: I purchased this item: Ebay link
    Should I be able to plug it in and have it automatically be recognized?
  5. #85
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    I say for those scared or worried about the usage...just don't use it.
    For all others, as you see I've been here a while and even posted in this thread a while back and I'm still using my phone as a modem and I still haven't been charged for it. The key is you don't want to download from Kazza and isht like that. Use it for web surfing and checking email. That's it.
    As far as cables, screw sprint you can get them off ebay dirt cheap.
    @pousevrika--You need to get the driver for your phone. DCXMan says he has access to those in post #80 or you can try to search for them on sprintusers.com's forum, sprintpcs.com or sanyo's website. It should be somewhere on sanyo's website. Once you have the driver you should be able to plug and unplug the phone w/o issue. Then just set up the dial-up network to dial #777 w/o a username or password and you're golden. You'll want to set up a constant ping because the connection will end every few minutes otherwise.
  6. #86
    Jan 2005
    Houston
    Oh believe me, I wasn't scared of it, just giving a heads up. I still plan on using it. The amount of money he said they "might" charge is small if your not using it for the things you mentioned. If they did charge you, it would be cheaper then going over your minutes or that damn 411 charge. I downloaded the sbc yellow pages onto my carpc to take care of that problem.
  7. #87
    Mar 2004
    anyone have a direct link to the PCS dialer software?
    Also, can anyone describe the ability to use the phone as a "network" rather then a "modem", also with what software that is needed for this?
  8. #88
    Jan 2005
    Houston
    Sent you a pm, someone gave me a link to get online without having to dial up with certain phones. You have to have PCS Vision. I dont' know if this is the software you want, but it connects you to the internet when you plug your phone into the USB cable. This came from soemone that has been doing it for awhile, but I downloaded the software and it works for specific phones.
  9. #89
    Nov 2004
    St Louis
    Quote Originally Posted by clean customs
    Me too, me too!
  10. #90
    Feb 2004
    Quote Originally Posted by pousevrika
    OK, here wat i did...
    first hook up your phone...
    let xp install the drivers....
    then go to network connection...
    add dial up connection (just like how u set up for like aol or other dial ups)
    make sure u pick your cell as new modemn (if u have pc moden installed)
    then make a shortcut on destop....
    hook the phone...
    click on the short cut...
    enter 777
    well u know the rest from the first page...
    that is it...no software....
    hope this help..sorry for the long wait..i bet u figured out already...
    oh well, this might help other...
    icet...
  1. wireless internet on the go...
    By robert42 in forum General Hardware Discussion
    Last Post: 01-05-2006, 10:08 AM
  2. UK Wireless Internet?
    By Max018 in forum Wireless Communications
    Last Post: 11-09-2005, 02:51 AM
  3. gotta love wireless internet from t-mobile! finally done right.
    By churnopol in forum Wireless Communications
    Last Post: 03-05-2004, 06:26 AM
  4. Any using Nextel for wireless carputer internet?
    By Rireal in forum General Hardware Discussion
    Last Post: 09-21-2003, 09:39 PM
  5. Free wireless internet for my car...
    By Defiler in forum General Hardware Discussion
    Last Post: 05-01-2003, 08:51 PM
