Try this.
click on wireless icon in tray(it will have a red cross on it if unconected)
an applet appears called wireless network conection, at the bottom is a button that says advanced. click this button.
A new box appears called wireless connection properties, it should have three tabs. click the middle tab "wireless networks"
goto the bottom where it says preffered networks.
click "add"
A box opens up with a space to insert your SSID, type in "any" and untick the box to enable wep (you wont need it for stumbling)
click ok.
dont know if this is the correct wayto go about it but it works ok for me. When you are ready to go stumbling go to the general tab and untick tcp/ip this will disable tcp/ip and other items dependant on it. This will stop you connecting to access points, also go back to the middle tab "wireless networks" and untick the box that says let
windows manage my network connection.
netstumbler should scan away quite happily then.
I am a n00b too so if any of the above is incorrect someone may let you know. failing that a search using the key phrases of your dilemma may yield an answer.
have a nice weekend.....paul
