Results 1 to 9 of 9
Thread: range of 802.11
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    range of 802.11
    Just being curious.
    let's say I want to put a 802.11 device in the carputer for sync with the house's network, what is the range to this wireless network?
    I would have to leave the car in the street, I do not have a garage at my appartment, and am not always able to park directly in front of the house.
    Would the 820.11 range a few hundreed feets for a standard access point?
    thanks.
    -Mars
    Newbie Merceputer's Avatar
    Jan 2004
    Nashville
    I would try 802.11g ( I have had better luck getting it at longer ranges), but i would really recomend a little outside antenna off Ebay to gaurantee a pefect Sync)
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    spec is 300ft, but that's assuming no interference from cordless phones, wireless video cameras, or microwaves. Metal, including house wiring, will also cause interference.
    Best bet is to get a good AP (linksys) and an external antenna for you car.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Mar 2004
    Houston, TX
    just a note to those looking to increase their wifi range on their home network:
    Try putting a high powered omni antenna as high as possible (I have had one in the attic before) You can usually get them at http://fab-corp.com/ go about halfway down the omni antenna page and you will see a 9dbi antenna for $56.95. (that will increase your output power by 8x)
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by Toups
    Oh man, for a few bucks more get the 12 dBi Omni w/ 3 deg Down Tilt. Now your talkin distance.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Mar 2004
    Houston, TX
    yes, but with that I would recommend placing the antenna above the roofline
    I also hope you have an open AP for your neighbors as your security would be compromised.
    Toups
    Feb 2004
    Montreal
    so with the proper equipment, I should be able to sync within about 2 corners of my appartment (and server/access point) ?
    is there any sync software that I should need?
    -Mars
    Mar 2004
    Houston, TX
    sync? The only thing this will give you is access to your home network.
    As far as a distance, you would need to calculate your EIRP, freespace distance loss and obsticle loss, then factor in your equipment sensitivity.
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Also depends on what hardware you use. I could barely get a signal using a linksys usb adapter sitting infront of my building. The Avaya usb adapter i just got allowed me to play a mp3 off the network as i drove down the drive from my building .
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
  1. subscript out of range error
    By loscooby in forum MediaCar
    Last Post: 02-17-2005, 09:00 PM
  2. Anyway to calculate wifi antenna range?
    By bizahh in forum General Hardware Discussion
    Last Post: 01-01-2004, 03:59 PM
  3. Over Range Abounding.. Grrrrrr
    By lightman in forum LCD/Display
    Last Post: 12-12-2003, 01:23 PM
  4. Wireless AP settings: Optimize for range
    By bombboyer in forum General Hardware Discussion
    Last Post: 10-29-2002, 12:51 AM
  5. IR remote range
    By AndyM in forum General Hardware Discussion
    Last Post: 03-12-2000, 09:46 PM
