those are both good suggestions - i forgot about the firewall function in XP.....i'm not so sure about enabling the guest account - but, windows networking always has been smoke and mirrors....![]()
i got pretty much the same setup got a hub in the back seat connected to a nic shared to netgear 802.11b pci card.
I had to enable guest account on the carputer so other pc's on the hub can see and access my shared folders.
instructions to enable guest account xp pro
1. goto control panel
2. click "administrative Tools"
3. click "Computer Management"
4. under "System Tools" click "Local Users and groups"
5. now click on the "Users" folder
6. if guest has a red x on it, right click on the guest and click "properties"
7. remove the check mark by "Account is Disabled"
8. enjoy
thanks for the input guys, but it looks like i'm still stuck with the same problem.
I tried the guest account thing
and the xp firewall,
but still no luck.
remember, the problem is that i cant get into the shared folders of my home computers when i'm using my carputer. Everything else is fine
mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
Total = $746....Carputer = Priceless
are the workgroups different? I remember having this problem when I first started my carputer.
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Win7 with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
Screen:Xenarc 700TSV
The Florida Meets Thread
no, they are all under the same name network name: mshome
that's really strange, as i haven't had any problems networking XP....
it really sounds like some sort of permissions issue with user accounts, that's the typical problem with this type of issue...
did you try making a new share to see if you could access that at all?
Dear o dear, the age old NTFS permissions problem, y o y do noobs always say yes to have their files hidden from other users?!![]()
hehe, anyways, u need to basically give everyone (or select users if you have an open network) permission to the files through NTFS, not through sharing as it sounds you have already done that.
You need to disable simple file sharing:
in explorer: tools, folder options, view, scroll to bottom, uncheck
Then right click on the folder you are tying to share, go to permissions, advanced (i think) and you need to add user: Everyone to the list of users who are able to access the folder (make sure you do it recursively as well).
Should do the trick, HTH.
no1knows
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
Without more information this is the best I can do from here.
The simplest way to fix this is to create a new user on all of the computers that has the SAME Username and Password. They also need to be part of the Administrators group. This should fix your problem, if not tell me.
@no1knows: hes using XP Home and cannot turn off "Simple File Sharing"
2003 Subaru Impreza TS
Staus: Done.. too lazy to make pictures lol.
ah apologies, havent used home much. i may be wrong but can you change ntfs permissions w/o it then? even XP Home should have some facility to manually edit ntfs permission values.
