Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: Network problems... tech support
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    Ok so heres the setup.
    2 pc's hardwired to a netgear MR814v2 router (xp home)
    1 carputer wirelessly through a usb 11mbps to the above router (xp Pro)
    I setup the network for the new carputer and I get internet and all is well. Hardwired computers can see the carputer and navigate through its shared files.
    HOWEVER,
    When I am using the carputer, I can only see the main shared folders of the hardwired computers, and when i click on them, i get a no permission/network path does not exist error.
    Any one have any clues on what to do with this.
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    when you look at my computer, do you see red "X's" through the icons that describe your drives? After you login.
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    Feb 2004
    Charlotte, NC
    nope, no x's anywhere
    Low Bitrate shadowpuck's Avatar
    Mar 2004
    do you have user accounts set up on any of these machines?
    Feb 2004
    Charlotte, NC
    what do you mean by user accounts?
    I have my own, administration accounts.
    And then i recently added the same account that i have on the carputer, to my hardwired computers(at the suggestion of someone else i was asking for help)
    So i have:
    My administrative account
    the same account that is on the carputer.
    None of them have passwords
    Mar 2004
    i was curious how you were accessing each machine - since XP can be setup to run - to a point - without user accounts....
    i was actually heading in the same direction of whomever suggested adding user names....
    just for info, how exactly are you trying to access the shares from your carputer? are you mapping a drive, or browsing the network?
    FLAC chut's Avatar
    Jul 2003
    or....Have you setup permissions on those shares?,
    are they indeed shared out?
    Do you have to login to a domain or are you using a peer to peer configuration?
    Feb 2004
    Charlotte, NC
    erg... I really dont know the answers to those questions. I can only tell you what i have done.
    I went to set up a home or small office network, and went through all that customization, placing the carputer on the same network as the other 2 computers.
    Then i went in and setup encryption on my router and the software on the carputer, and that all works.
    I haven't setup permissions on the shares, i dont know how. I just stuck it on the network. And right click>shareing and security> share on this network.. and then typed the network name
    if what i did above shared them out, then yes... i can see and navigate through shared folders between the original 2 hardwired computers.
    it's set to infastructure, if thats what your asking. I don't login.
    this is the actual error
    \\Exavier\myshared is not accesible. You might not have permission to use this network rescource. Contact the administrator of this server to find out if you have access permissions.
    thanks for the help
    Mar 2004
    one thing to consider trying is setting up a new share and seeing if you can access it from the carputer....
    this really seems to be some type of permissions or share issue....
    what i would try is creating a temporary shared folder on the c drive of either of the hardwired computers....
    to do this, open up my computer or get to the c drive. create a new folder, call it whatever you want - say test.
    then, right click on the new folder and choose sharing. then, choose share this folder...then, go to the carputer and try to map to the share...you can map a shared drive in any number of ways depending upon how you have XP configured. one way would be to go to network places or my computer, right click and choose map network drive....then, for the drive name type \\hardwired computer name\folder name...
    you might have already tried this, but i'm just trying to determine if the carputer has the same rights as the other machines....
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    I just fixed a friend's PC that was having this problem. Make sure that you don't have the XP firewall turned on for either computer. Sometimes this is on by default. Your router should supply the firewall functions that you need, so you don't need the XP firewall.
    In the properties for your Local Area connection, on the Advanced tab, uncheck the "Protect my computer...." box.
  1. Problems, Problems. Need some support.
    By mhermann in forum General Hardware Discussion
    Last Post: 04-22-2004, 08:59 AM
  2. Network problems... tech support
    By cadence117 in forum Wireless Communications
    Last Post: 04-20-2004, 06:47 PM
  3. Wi-Max : A viable alternative to Wi-Fi?
    By Maxis24 in forum Wireless Communications
    Last Post: 03-26-2004, 06:35 PM
  4. When will ME support plug-in???
    By vbi in forum ME Archive
    Last Post: 10-31-2003, 07:39 AM
  5. For the love of tech support
    By ShinkunoNamida in forum Off Topic
    Last Post: 05-21-2002, 01:12 AM
