Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 61
Thread: o2 GPRS Pay as you Go (UK) might be free
  1. #21
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    anyone know if they are still doing free gprs?
    Thanks.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
  2. #22
    Variable Bitrate Dracos's Avatar
    United Kingdom
    Quote Originally Posted by dan__wright
    Thanks.
    Free O2 sims - get them while you can!
    read
  3. #23
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    ok.. can confirm I have been using a unreg'd o2 pay as u go sim. with zero credit on it. I used it all day saturday surfing and on msn.. and its still working great. I do have a couple of spare sims thats why am bashing this one just to see if its capped. It does say.. free upto 1mb month. I have well gone over this !!
    btw I'm using a gprs cf card, in a pcmcia adapter.. I got this free with my pda from dell ..
    cheers
    CdR
  4. #24
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by CdRsKuLL
    cheers
    CdR
    Cdr, if they say it doesn't work, it doesn't work
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  5. #25
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    I am a believer
    A lot of posts are saying one thing and you guys are saying another. It apparently works now but not at the end of the month
    I should have my chip in a few days. I hope it does last longer than the end of May.
  6. #26
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by rickster
    I am a believer
    OK. This is what I understand:
    http://www.o2.co.uk/productsservices...0,,112,00.html
    "O2 Active via GPRS is charged at rate of 2.35 per MB"
    o2 WAP was FREE before Febuary 2004, then they started charging.
    Also, o2 say it cannot be used for mobile internet, ONLY WAP.
    So.... What the ***** are we on about then??
    Well, I got my o2 sim as it was cheaper than Orange's 4 a meg...
    Then I found it WAS possible to get web access by putting the WAP gateway in as a proxy server in IE.
    Then I noticed it didn't ALWAYS charge for use...
    Then both Jamez_Warner/ Cloudy and my brother lost their Net at home and started using it too and discovered it worked fine after you ran out of credit.
    Then we noticed even with the FREE o2 sims, it STILL works without topping them up initially.
    I would however recommend no-one takes the **** with it, and is happy to pay the 2.35 a meg if they HAVE to, as o2 will probably stop this from working at some point.
  7. #27
    Feb 2004
    Manchester
    well all I did was take it out of the packet.. inserted it into my mobile.. turned on. About a min later I got a txt saying.. "Do you want to activate gprs2.. I said yep..again a min later another txt which setup my gprs settings. I did however need to change the apn to payandgo.o2.co.uk once this was done I could surf on wap via my mobile phone !.. so then after some help from mp3car_uk I rigged up my laptop.. stuck in the proxy and bobs your uncle.. infact i'm on it now :-)
    Live 'Free' tracking in FreeDrive here we come :-)
    CdR
  8. #28
    Aug 2003
    Warwickshire, UK
    CdR
    I've also got a special webcam app I wrote for uploading pgs via the o2 access too
  9. #29
    Feb 2005
    Essex, UK
    I will follow your settings on the other thread, and set up ie to use a proxy. I will let you know when I get the chip.
    Thanks for all the info.
  10. #30
    Raw Wave
    Jun 2004
    On the beach
    Yup, it works perfectly .... slow at times but all I need it for is low speed access.
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 02:37 PM
  2. UK - T Mobile Unlimited GPRS for 34 a month
    By Jamez_Warner in forum Wireless Communications
    Last Post: 05-16-2004, 01:26 PM
  3. FREE Wireless internet on your carputer via GPRS from t-mobile
    By bankingdom in forum General Hardware Discussion
    Last Post: 05-11-2004, 01:56 PM
  4. X10 Lola remote free pay for shipping only
    By gambit32 in forum Input Devices
    Last Post: 04-15-2004, 12:39 PM
