Results 1 to 10 of 10
Thread: T-Mobile Internet
    Low Bitrate cavramair's Avatar
    Aug 2003
    Ohio
    T-Mobile Internet
    OK, I have a Nokia 3595 with the usb cable that hooks up to the car pc. How exactly do I get internet through this thing. Do I dial up, or how to I get high speed? Sorry if this has been covered before, I did a search, but I couldnt get a clear answer.
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Not sure if the 3595 is GPRS capable but, you should check that first. If it is, than I think you would use the Nokia Connection software to just connect the phone to the internet. It's just like dialing up somewhere except the # you will be dialing is *99***1#, user id: wapuser1, password: wapuser1
    You must enable free WAP on your account by calling customer care (it's free - so don't pay for their $4.99 T-Zones plan).
    If your phone is not GPRS capable, than you will dial-up like a normal dialup connection (i.e. dialing an ISP through you phone). Again, your phone will connect via the cable but you will be dialing your local ISP # (this requires that you have some sort of ISP account and local dial up #). This method is called Circuit Switched Data (CSD) and it is MUCH slower than GPRS.
    GPRS is unlimited use though the free WAP is limited to certain ports. Do a search here for setting up a server that would allow you to access all ports via free wap. GPRS charges are measured in amount of data downloaded but, free WAP is free and you will not be charged. CSD is charged by using your phone minutes.
    This is very cursory information - but, your first step is to find out which types of connection your phone supports and second to download the Nokia connection software.
    If you need more information check out http://nokia.howardforums.com.
    -HD
    Aug 2003
    Ohio
    Thanks for the reply, that is the exact information I was looking for. I already pay for the t-zones, so I guess I am set up that way. Once I get the cable, I will try it out and let ya know how it works out. Thanks again!
    -Drew
    -Drew Taylor
    2000 Grand Am GT PC
    Variable Bitrate NoPistonPC's Avatar
    Boston
    Here is how I got mine working in Windows XP:
    1) Go to "Control Panel/Phone and Modem Options"
    2) Click on the "Modems" tab, click on the "Add..." button
    3) Check the box that says "Don't detect my modem" and click "Next"
    4) Select "Standard 19200 bps Modem" and click "Next"
    5) Select the COM port that you have your phone attached to (it might be a virtual COM port if you are using IR, USB or bluetooth)
    6) Click "Finish"
    7) Go to "Control Panel/Network Connections" and click on "Create a new connection"
    8) Click "Next", then choose "Connect to the Internet" and click "Next" again.
    9) Choose "Set up my connection manually", then click "Next".
    10) Choose "Connect using a dial-up modem", then click "Next".
    11) Name your connection, for example "T-Mobile GPRS", then click "Next"
    12) For the phone number, enter "*99#", then click "Next"
    13) Leave username and password BLANK, then click "Next"
    14) Click "Finish". You're done!
    When you click on that connection now to connect, make sure you leave your username and password blank.
    1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Hey,
    I have a Motorola V300 with Tmobile. I pay $4.99/month for Tzones. I also own a Sony Clie Handheld (NX60, Palm OS 5.0) I bought a data cable that goes from my phone to my PDA to be able to connec to to the internet on my PDA. I really despise WAP. I put all the info from a web site that I found into my PDA, and it is just not working. Below is the .Zip file of the site. Please help
    Peace,
    Rafster
    Attached Files Attached Files
    Low Bitrate riuster's Avatar
    Jul 2004
    NYC
    Quote Originally Posted by NoPistonPC
    6) Click "Finish"
    Can you run Internet Radio with your phone via GPRS???..did you try this
    Jun 2004
    Los Angeles
    Quote Originally Posted by rafaelsherman
    Hey,
    Peace,
    Rafster
    1.) DON'T pay for T-Zones! It's free - refer to my first post for more info.
    2.) Never connected to a PDA via data cable so I can't help you there. Try the forums @ brighthand.com for more help.
    -HD
    Jul 2002
    Seattle WA
    Question regarding "free" t-zones...
    Is this free internet access for use through your pc using the cell as the "modem"?
    Or can I get access to the WAP websites like Fox Sports or yahoo without actually having to pay for t-zones? My account does have the free WAP available. I have a Sony Ericsson T610. It's a new phone and can't quite figure out how to set up the free internet.
    Thanks for any info.
    New site at
    http://customcarpc.dreamhost.com
    http://home.attbi.com/~rbarr110
    2002 Toyota Tacoma Doublecab
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by hd54321
    Actually, I don't pay for anything.
    My boss pays for my line.
    I get 1000 Anytime, Free N/W, Tzones, 20 Picture messaging, and 500 text.
    Peace,
    Rafster
    Mar 2004
    Maryland/NOVA
    t-mobile is AWESOME!!! just got mine working using an mpx200
    thanks guys.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 02:37 PM
  2. Careful to Mobile CPU buyers! false advertising!
    By gospeed.racer in forum General Hardware Discussion
    Last Post: 06-04-2004, 04:08 PM
  3. Mobile internet
    By vcbb5 in forum Input Devices
    Last Post: 03-01-2004, 07:28 PM
  4. Any using Nextel for wireless carputer internet?
    By Rireal in forum General Hardware Discussion
    Last Post: 09-21-2003, 09:39 PM
  5. Mobile internet
    By Twostep in forum General Hardware Discussion
    Last Post: 02-04-2002, 03:35 PM
