Seems we need a WiFi FAQ, I might not be the one to start this but here goes. Firstly:
What's the difference between the different protocalls a/b/g and such?
(From:
http://www.webopedia.com/TERM/8/802_11.html)
Where can I mount my antenna?
You should really mount your antenna outside your car, metal will block the high frequency WiFi signal pretty easily. Glass will interfere some but not as much as metal.
Can I use my car's AM/FM antenna to recieve wireless?
No, as antennas must be tuned to the proper length depending on the frequency of the signal. Radio signals are a much lower frequency than WiFi and as such require a much longer antenna. Also, WiFi antennas send as well as recieve so they must be powered, powering an AM/FM antenna with your wireless card can fry things so be careful!
What else? :confused:
What's the best antenna?
What's the best wireless card?
