Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 76
Thread: WiFi FAQ
  1. #41
    Dec 2006
    Owen Sound, Ontario, Canada
    Actually...
    Wireless capabilities are now updated to the draft N standard which has a bandwidth rate of about 300 Mbps and has the largest range (about 50m/160ft or greateg)and also has a feature called MIMO which means "multi in, multi out" it basically uses multiple connections to increase the rage and speed which equalls very much happy. they are kinda costly and usually have an external antenna plus it's still under development but if you wanna learn more go here: http://en.wikipedia.org/wiki/IEEE_802.11
  2. #42
    Constant Bitrate agniusm's Avatar
    Oct 2006
    Lisburn
    I am a little bit into wifi. have builded few antennas myself . I have a dish reflector antenna which exceeds 10miles. Using Senao 200mW PCMCIA adapter.
    I have a USB wifi (belkin) and waiting for connectors to modify it by adding external antena socket (SMA). Hombrew antenna i will build, is on this site: http://martybugs.net/wireless/collinear.cgi
    Many people saing that orinoco cards are good.
  3. #43
    Newbie Bizarro's Avatar
    Dec 2006
    Texas
    a good selection of antennas
    and amplifiers
    List of free Wifi hotspots by US state and Europe
    List
  4. #44
    Newbie BlkAvalanche's Avatar
    Feb 2007
    Pleasanton
    I just spent 20 min trying to read this sticky with my wife telling me to get off the computer because it is valentines day and I should be spending time with her all because I wanted to find out what a good usb wifi adapter might be. After reading this, I have no clue! I now know what is leagal and illegal but that deos me no good unless I can figure out what wifi usb adapter to buy Is there any way we can get some kind of poll that shows what wifi adapter people are using and how effective it is? Kind of like the one that was posted about gps softwear. Even if some of you can describe and or give links to the adapters and or antennas you are using. If I am speaking out of turn, let me know. I am still new
    Money can't buy happyness but it sure as hell makes misery easier to live with!
  5. #45
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by BlkAvalanche View Post
    What car pc are u using is it laptop, or a base unit style?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  6. #46
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    1. If you like your wife, don't surf the net on Valentine's Day, period!
    2. I've owned a number of adaptors, D-Link USB, NetGear PCI among them. They've all worked fine. Buy a brand name and you'll most likely do well with it. However, you might want to buy a model that allows an external antenna as range is an issue in the car. This makes it more expensive, but is better than poor range which effectively ruins your investment in the adaptor in the first place.
    Check the install that others have and see what adaptors they are using. You'll probably find that there is a wide range.
    Want to:
  7. #47
    Feb 2007
    Pleasanton
    Quote Originally Posted by jonessc View Post
    It is a base unit style. After doing a little more research I found this usb adapter by Engenius. From what I can find, everyone who owns one loves it.
    http://www.netgate.com/product_info....roducts_id=297
    I was going to add an external antenna and was trying to decide between these two
    http://sharperconcepts.zoovy.com/product/YSC-HG2409MGU
    http://cgi.ebay.com/WiFi-7-dB-Magnet...QQcmdZViewItem
    What do you all think about these two? Is it really worth the $40 for an extra 1.5 dbi? How much more range will this get me?
  8. #48
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    Question Tracking and automatic internet connection
    I'd like to bump one of the earlier posts.
    Quote Originally Posted by Chairboy View Post
    A popular use of WiFi in car computer setups is called 'War Driving'. This is a process where you run a program that looks for access points that allow you to access the internet. A typical use of that might be to have a program that periodically grabs a few K worth of data from a traffic site or occasionally uploads your GPS coordinates to a server for tracking.
    War Driving, despite the name, is completely legal. Connecting to personal networks to access their internal data, however, is not.
    The most popular program for doing this on Windows is called NetStumbler. It is available at http://netstumbler.org/ and supports many popular chipsets. It can also use your GPS to assign a location of each access point found so you can maintain a database. Driving from work to home in Los Angeles, I typically see upwards of a hundred access points, half of them without WEP encryption enabled.
    On Linux, popular programs include AirSnort and Kismet, the latter a tool that can also detect people running NetStumbler.
    I have downloaded netstumbler but I do not understand howto make the carputer automatically connect to internet to ftp my tracking info. If I am in the car, sure, I can manually connect to one specific AP or make the carputer use my phone via BT for internet access. But a car thief is not likely to do that....
    Has anyone done this?
    Edit:
    I found an article about this and started this new thread: Automatic connection to unknown Wifi net
  9. #49
    Dec 2006
    Jacksonville, FL
    Not sure if this is the right place but if not sorry. I have 2 systems in my car,
    both in the same case. I am planning on using clearwire for internet since it is in my city. I want to network both together to use the clearwire but also have wifi option for when I am out of the coverage area of clearwire. I know I can use a wired or wireless router for the cleawire and joining the 2 computers but how would I add the wifi and what equipment would I need(external antenna preferably and hot spot connection not broadband card like sprint or verizon.) Thanks.
  10. #50
    Sep 2005
    Stockholm, Sweden
    Your problem is similar to mine.
    So Clearwire is a wireless ISP where you live with access points all over the place.
    If you connect your pc's by wire (why 2 pc's?) and connect a Wifi USB stick to one of them you can use that pc as a gateway to internet for the other one.
    As long as you move within clearwire, no problem, but when you move outside you need your wireless network to connect automatically to whatever free hotspots you pass thru.
    The easy way is to get a Wifi dongle that can be configured by MS network. (You are using WinXP SP2?) Check out the thread I linked to.
  1. wifi usb solution
    By turbochris in forum Wireless Communications
    Last Post: 07-22-2004, 11:59 AM
  2. Help finding a 54g PCI wifi card for Procase'd carputer
    By NJay in forum General Hardware Discussion
    Last Post: 01-21-2004, 04:04 AM
  3. FAQ question about Skin installing
    By QuickCarl in forum ME Archive
    Last Post: 11-02-2003, 12:46 PM
  4. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
  5. The FAQ? What happened?
    By Aaron Cake in forum General MP3Car Discussion
    Last Post: 06-09-2001, 05:32 PM
