Page 1 of 8 12345678 LastLast
Results 1 to 10 of 76
Thread: WiFi FAQ
    Jul 2004
    Santa Barbara, CA
    Question WiFi FAQ
    Seems we need a WiFi FAQ, I might not be the one to start this but here goes. Firstly:
    What's the difference between the different protocalls a/b/g and such?
    (From: http://www.webopedia.com/TERM/8/802_11.html)
    There are several specifications in the 802.11 family:
    802.11 -- applies to wireless LANs and provides 1 or 2 Mbps transmission in the 2.4 GHz band using either frequency hopping spread spectrum (FHSS) or direct sequence spread spectrum (DSSS).
    802.11a -- an extension to 802.11 that applies to wireless LANs and provides up to 54 Mbps in the 5GHz band. 802.11a uses an orthogonal frequency division multiplexing encoding scheme rather than FHSS or DSSS.
    802.11b (also referred to as 802.11 High Rate or Wi-Fi) -- an extension to 802.11 that applies to wireless LANS and provides 11 Mbps transmission (with a fallback to 5.5, 2 and 1 Mbps) in the 2.4 GHz band. 802.11b uses only DSSS. 802.11b was a 1999 ratification to the original 802.11 standard, allowing wireless functionality comparable to Ethernet.
    802.11g -- applies to wireless LANs and provides 20+ Mbps in the 2.4 GHz band.
    Where can I mount my antenna?
    You should really mount your antenna outside your car, metal will block the high frequency WiFi signal pretty easily. Glass will interfere some but not as much as metal.
    Can I use my car's AM/FM antenna to recieve wireless?
    No, as antennas must be tuned to the proper length depending on the frequency of the signal. Radio signals are a much lower frequency than WiFi and as such require a much longer antenna. Also, WiFi antennas send as well as recieve so they must be powered, powering an AM/FM antenna with your wireless card can fry things so be careful!
    What else?
    What's the best antenna?
    What's the best wireless card?
    Jul 2004
    Right now the highest speeds available in a wireless network solution is 108mbps. Remember that the speed is the theoreticly max. You will never reach that speed.
    For every obstacle in the way, wood, concrete, glass, rain, humidity, will make the signal weaker. Always try to have "eye contact" for the maximum preformance. The standard WiFi products of today usually has a maximum range at 400 yards(although it's possible to extend the range with a different antenna). There are known bridge stations that can establish a stable signal at a distance of 10 miles or more.
    There are diffrent types of antennas, they go in to two sections:
    Omni directional - antennas that sends the signal in every direction, 360'. these antennas are usually included with the base station, excellent when you want to move around.
    directional antennas (don't know the name in english). That only sends in one direction, usually used for connecting another base station or extending the signal in one direction.
    Can't think of anything more to add, just ask!
    Jan 2003
    Ruston, LA
    I'm going to stick this, keep it clean please.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    FLAC Chairboy's Avatar
    Jan 2004
    A popular use of WiFi in car computer setups is called 'War Driving'. This is a process where you run a program that looks for access points that allow you to access the internet. A typical use of that might be to have a program that periodically grabs a few K worth of data from a traffic site or occasionally uploads your GPS coordinates to a server for tracking.
    War Driving, despite the name, is completely legal. Connecting to personal networks to access their internal data, however, is not.
    The most popular program for doing this on Windows is called NetStumbler. It is available at http://netstumbler.org/ and supports many popular chipsets. It can also use your GPS to assign a location of each access point found so you can maintain a database. Driving from work to home in Los Angeles, I typically see upwards of a hundred access points, half of them without WEP encryption enabled.
    On Linux, popular programs include AirSnort and Kismet, the latter a tool that can also detect people running NetStumbler.
    Jan 2004
    NetStumbler .4 will actively prevent a computer from going into Hibernation or Standby, so if you're using it in your car you need to exit the program before turning off your car. If you don't, even your Opus will be unable to send it to sleep. An enhancement request has been posted to the Netstumbler.org BBS to make this setting configurable.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    How about a list of good wifi devices? I've tried this microsoft one and it was complete garbage. I locked once ever while wardriving to load up google.com.
    I know orinoco silver is a good choice, anything else? I'd prefer something usb.
    Mine needs to be updated.
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by samc
    Orinoco makes a USB version. There is actually a PCMCIA card connected to a USB adapter inside the plastic case. The Orinoco card inside allows you to attatch an external antenna. I'm not sure if they are still made by Orinoco or another company. I got one off ebay a few months ago. Highly recommended.
    Picture of the goodies inside:
    More Info: http://www.cablemodeminfo.com/quickt...inoco.html-ssi
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Please Could We get a description of what is best to look for when buying antenna's / adapters. Explanations of the transmit power (mw, w, Db's)
    Also a description of Connections (Pigtails, RP-SMA, SMA, TNC, RP-TNC etc, etc...)
    Here is a good FAQ on wireless: http://www.seattlewireless.com/faq.asp
    And Here is a list of cards, not sure what all of the data means (Power, which is better w, mW, or dBmhttp://www.seattlewireless.net/index...rs_5f802_5f11b
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Maximum Bitrate freestyler's Avatar
    Jan 2002
    Chaska, MN
    Quote Originally Posted by Chairboy
    albeit somewhat correct that statement isn't 100% correct.
    wardriving is "The benign act of locating and logging wireless access points while in motion"
    has nothing to do with locating access points for accessing the internet, it's merely a statistical data gathering method.
    and your "typical" use is incorrect, it doesn't grab ANY K's of data, it merely notes where a radio beacon is being broadcasted.
    1997 Jeep Wrangler Rugged Waves
    Ebay Stuff For Sale
    Maximum Bitrate nFiniteTuning's Avatar
    Tijeras, NM
    Newbie!
    I didn't even know what WiFi was until just now when I searched "Satelite Internet" on google. Could I get a newbie description of this?
    I see people saying a 360 range of 10 mile radius? Does this mean I can setup some kind of wireless network device in my car, and have it transfer and recieve network/internet data from my pc which is loged onto the internet? And drive around too?
    ....I really would love to be able to drive around town and have a connection. The main area I cruise (drive to and from for the hell of it) in my city (albuquerque, nm) is about a 10 mile radius, most likely smaller. From the middle of the city to my home outside the city in the mountains, is 18 miles....soo that leads me to belive that Albuquerque is about 20 miles long and 15 miles wide. And I dont drive to those area's...
    1987 Pontiac Fiero GT
    XPCarputer Coming Soon
    [IIIIIII---] 70% Complete
    XPC Model SN41G2V2
    AMD AthlonXP 1800+
    2× Mushkin 256MB DDR
    Pioneer DVDRW
    80GB 7200RPM UltraATA HD
    Windows XP MC2005
    XM Satellite Radio
    •ñFïnïtε Τחטіתģ•
  1. wifi usb solution
    By turbochris in forum Wireless Communications
    Last Post: 07-22-2004, 11:59 AM
  2. Help finding a 54g PCI wifi card for Procase'd carputer
    By NJay in forum General Hardware Discussion
    Last Post: 01-21-2004, 04:04 AM
  3. FAQ question about Skin installing
    By QuickCarl in forum ME Archive
    Last Post: 11-02-2003, 12:46 PM
  4. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
  5. The FAQ? What happened?
    By Aaron Cake in forum General MP3Car Discussion
    Last Post: 06-09-2001, 05:32 PM
