Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: House eats wireless signal
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    I just moved out of the barracks into a house. When I lived in the barracks, my DLink DI-624 worked great. The barracks was nothing but concrete, steel, and high voltage power; the worst conditions possible for wireless. Needless to say, I got better range there than I do now in this house.
    The house I am living in now was probably originally built in the 1940's. I have it set up in the living room where I can only get maybe 20 feet of range. Normal excellent connection is about 10 feet. Also, if anything gets in the way, I loose my connection. If someone stands between my laptop and my router, the connection is gone.
    I've checked the antenna on the router and it seems fine. I also ensured that the router is putting out 100% of power which it is. I don't think that there is anything wrong with the hardware. I think that the house is eating all my wireless signal. I've moved the router all around (trying to get it higher or in a better position) and nothing seems to help. I'm wondering if a high gain antenna will be able to punch through this signal eating monster that I have to live with.
    Any suggestions?
    Derek
    Router = DLink DI-624
    wNIC = DLink DWL-650
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Feb 2004
    Elmira NY
    is thare tin on the insulation? or mettle sideing? or or thin tin backing of the dry wall? tho's would stop it REAL quick
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    Do you have a microwave, or a wireless phone in the 2.4 Ghz frequency?
    If it was built in the 1940's you may just have really bad EMI from old wiring.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    Mar 2002
    Austin, Texas
    Bad wiring could be it. This house only has one grounded outlet (three-prong) in each room. All other outlets are regular two-prong outlets.
    There is siding on the outside of the house but wouldn't that make it so the signal outside the house suck?
    Microwave is clear in the other end of the house (rarely in use) and there are no cordless phones hooked up.
    Derek
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    It (metal in the walls) still would have to be BETWEEN the router and the computer to make any difference (even keeps noise outside).
    Test with another router/wifi card in the same house. Could be a nearby source of noise (check s/n ratio with netstumbler), could be your equipment got damaged during the move, could be the power in the house that carries static...
    Troubleshoot
    Joa
    Mar 2002
    Austin, Texas
    I just tested with my girlfriend's laptop (802.11g built-in). She gets and even worse signal that I do. I have both laptops sitting side-by-side on the floor. They are approx. 6 feet away from the router which is sitting about two feet higher than the laptops.
    Windows and NetStumbler are giving my contradictory readings.
    Windows
    My Laptop: 5 bars (excellent)
    Her Laptop: 2-3 bars (low to good)
    NetStumbler
    Code:
    Laptop    Speed   SNR   Signal+  Noise-  SNR+   Maker
    Mine      54Mbps  16-17    15     -100    21    DLink
    Hers      54Mbps  25-34   -60     -100    40    Compaq
    Anyone wanna try to figure this out?
    Derek
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    what else do you pick up with netstumbler, try changing the channel to 1 that helped with mine
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
    Mar 2002
    Austin, Texas
    Quote Originally Posted by GruvThang
    No other APs are seen in NetStumbler. The router will not let me change the channel. It's locked on 6.
    Derek
    Feb 2004
    Quote Originally Posted by d_sellers1
    Derek
    That's because your router is setup to use Super G mode. You can disable Super G by going into the router and going to Advanced > Performance and select disabled for Super G. You will then be able to change the channel. Change the preamble to short as well. If it is set to short then switch it to long. Make sure you have firmware 2.42 as well, you can check by going to Status. If you don't have firmware 2.42, go to http://support.dlink.com/ and find your product and download firmware 2.42. Then log back into the router when you're wired to it (dont do it wireless) and go to Tools > firmware and upgrade the firmware there.
    (Firmware versions I'm speaking of coincide with a Revision C of your router, you can find the revision underneath the router's sticker, H/W: XX, although the steps are the same if you had a Revision B)
    One other thing, the DWL-G650 utility has problems reporting signals if you're using the D-Link utility, the Windows utility reports the correct signal/speed. But don't let the signal strength fool you on the D-Link utility.
    Jul 2004
    Quote Originally Posted by slasherx
  1. Wireless router to wireless router wirelessly
    By Jackso in forum Wireless Communications
    Last Post: 02-22-2010, 12:30 PM
  2. Cell Booster / Amplifier
    By GruvThang in forum General Hardware Discussion
    Last Post: 07-28-2004, 07:35 AM
  3. 3.1 Mile Wireless Bridge
    By Suprapc in forum Off Topic
    Last Post: 06-09-2004, 10:56 PM
  4. wireless card or wireless car and access point?
    By vanroth in forum Wireless Communications
    Last Post: 06-08-2004, 11:46 AM
  5. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
