Results 1 to 10 of 10
Thread: wifi proggies??
    Aug 2002
    longview washington
    wifi proggies??
    whats a good program for locating wifi points ..
    that will work with a netgear ma401 pcmcia
    netstumbler does nto support it unless your using xp
    aerosol .. is not all that nifty to use but it works is there anything else ?
    WINNER!!!!
    run-on sentance comp 2002!!
    Jun 2003
    Memphis - TN
    Netsumbler
    Sumverter for mappoint 2004
    http://wigle.net/
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Aug 2002
    longview washington
    i am not running linux
    and netstumbler does not support my ucrrent pcmcia wireless card in win 98
    it does in xp using a universal driver thing
    but .. i can't run xp on a 120mhz tablet computer
    WINNER!!!!
    Low Bitrate l9nux's Avatar
    Aug 2004
    San Francisco
    I've got problems with my wardriving setup too. I have NetStumbler, with a Netgear WG311 v2 PCI card. NetStumbler works, but it won't detect the signal strength, and sometimes it detects access points for a few minutes after they should have disappeared!
    Has anyone got NetStumbler working with a PCI card?
    Aug 2004
    Germany
    hm i got it working well with a buffalo g54 pcmcia card no probs since the new version the old version did close without reason sometimes
    Golf 3 CarPc Status
    ///////////////50%--------------/
    PSU:Inverter
    GPS:BT GPS
    PC: Slim notebook with 10.4"touch, external DVD.
    Dock for car is in production.
    Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Netgear MA401 works with windows 2000 but not windows 9x Im guessing it works with XP too since 2000 and XP use the same drivers. It does do the SNR in netstumbler which I couldn't get some other netgear cards to do tho.
    It uses the prizm chipset, so you can get it working under linux fairly easily.
    As for WG311 v2 PCI I believe this may be the same card as mine... is yours the G version? Mine does the same thing in lagging when an AP is found, but it also happened with my other USB card, so it might just be netstumbler will have to test a different brand of wireless cards to make sure.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Aug 2004
    San Francisco
    Yesterday 03:38 PM
    Yes my WG311 v2 is the 802.11b & g version, but it's so annoying when I can't see the signal strength! Because I'm using Win XP on a PC (not a laptop), I need a PCI card that works. Unless there are any alternatives to NetStumbler for Win XP?
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    i got xp, netgear MA311 pci, using netstumbler, all works, no problems
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Aug 2004
    San Francisco
    Talking
    Great, does your signal strenth work? Also, mine detects AP's a few minutes after they should have gone!!
    Mar 2004
    Fort Myers, Fl
    yes, signal strength works, I did have problems with netstumbler 4.0, went back to 3.0 and I had no problems since.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
  1. WiFi FAQ
    By jrtf83 in forum Wireless Communications
    Last Post: 12-30-2009, 06:16 PM
  2. How good is your Wifi Antenna?
    By Custommx3 in forum Wireless Communications
    Last Post: 03-08-2007, 11:03 AM
  3. wifi usb solution
    By turbochris in forum Wireless Communications
    Last Post: 07-22-2004, 10:59 AM
  4. XM over WiFi?
    By cabm in forum General MP3Car Discussion
    Last Post: 02-08-2004, 10:11 PM
  5. Help finding a 54g PCI wifi card for Procase'd carputer
    By NJay in forum General Hardware Discussion
    Last Post: 01-21-2004, 03:04 AM
