Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: ideas for increasing wifi signal from within trunk?
  1. #11
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by ppgt94
    You really think some geek is going to steal your little 802.11 antenna? I have one (off ebay). I pop it out on demand. I have a Orinoco Gold Classic card w/USB adapter in the glove box connected to the hub.
    I doubt your antenna will work very well in your rear window deck unless it's metal. Most mag mount antennas are "mag" mount for a reason. It needs to be grounded (body metal = ground)
    Just a slight CLARIFICATION. 1/4 wave Mag mount, which in actuality, are what are called Ground Wave antennas, need a reflector to work at stated specs. This reflector is metal, and generally has to be a size equal to the wavelength of the antena in size. There are some ways around this, but in this situation, you would be using a 1/4 wave antenna. The equation to determine length for a 1/4 wave antenna is 234/frequency in megahertz=length of 1/4 wave antena in feet. So 234/2400=.0975 feet, or 1.17 inches. As long as you have about 2.34 inches diameter of metal under the antenna, whether the antenna is "STUCK" to it or not, you should be o.k. Even without the metal, the antenna will work better then when in the trunk, just not to specs, or as well as it could.
    Michael
  2. #12
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    where is your access point situated?
    CarPC status: iPod, 3,456,217 songs so **** you
  3. #13
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by cheerio
    or a better idea is to buy a cheap car like mine, made out of mostly plastic. Seems to be transparent to most signals . Hell. i live in san antonio, and i can pick up radio stations in Houston, there has to be an explaniation for that one.
    It's a plastic car uprising!
    Compusa has a nice omni directional antenna with 3 diffrent connectors for diffrent wireless cards. I've been testing it in the car with good results. I am thinking of just mounting it with a suction cup in the back window. Works a whole lot better than one of those little tiny mag mount antennas from ebay.
  4. #14
    Variable Bitrate blurp's Avatar
    Sep 2003
    Hampshire, TN
    Quote Originally Posted by jcdillin
    Get 'em while you can. The 2006's are going to be steel body. The plans are in the works right now to completely re-tool the plants in Spring Hill.
    www.bradleyjacobs.com
    There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
  5. #15
    FLAC ppgt94's Avatar
    May 2001
    USA
    Using Netstumbler's SNR graphs can be really helpful in finding a optimal location and orientation (completely vertical worked best for me).
  6. #16
    May 2003
    Miami, FL
    Quote Originally Posted by blurp
    Doesnt that just suck, guess i'll just go to a 2001 or 2002 then
  7. #17
    Sep 2003
    Hampshire, TN
    You have just never seen them at "Door Finesse" beating the crap out of your car with a rubber mallet and bending the door with their knees trying to make it fit right.
  8. #18
    build an antenna and put it on your rear deck in the window. thats about the best way to do it. if you want to keep it in the trunk, your signal will continue to suck ***. electric fields such as that given off by wireless networks will not exist inside hollow conductors (aka your trunk). physics heh.
  1. WiFi FAQ
    By jrtf83 in forum Wireless Communications
    Last Post: 12-30-2009, 06:16 PM
  2. ideas for securing case in trunk?
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 07-09-2006, 05:22 PM
  3. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 08:30 AM
  4. some accessory ideas
    By moossmp3 in forum General Hardware Discussion
    Last Post: 09-08-2000, 05:27 PM
