Results 1 to 10 of 18
Thread: ideas for increasing wifi signal from within trunk?
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    i have my computer inside my trunk and the signal is pretty low when parked in my driveway
    im using the stock rubber duck antenna on a belkin 54g pci card
    any ideas on increasing the signal?
    putting the antenna outside the car would be best but im looking for a cleaner, more permenant solution
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    What about multi-linking? I was thinking of trying that now that I have two of the same dell G cards.
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    Sep 2003
    Northern Va
    Here is what I did. I took a cheap 802.11g card, and cut the wire going to the little stupid anteanna. Then I got one of those 2 feet high magnecic mount Antennas, (It was off a torn down cell phone tower) and tuned it by cutting it to the right length. I then spliced the cabels together. Some radio enthusiests will swear that a 5 min splice is a horrible thing, but in your situation, it will reduce your range by about 4 inches.
    You splice a coax cable by first removeing the outer coverang by about 1.5 inches on each wire. Then you push back the metal 'fabric' grounding around the cable. cut about a 1/4 of an inch off of the inner wire and insolation. This is so that the grounding meshes will meet. Then strip the inner insolation wires, and solder. Carefully wrap electrical tape in the aria where the innter insolation is gone, so that it meets in highet with the inner dielect. After that, push the two meshes together, and wrap with electrical tape
    Enjoy
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Or just buy an antenna off of E-Bay, the one I got increased my signal alot! Although others say it was crap, with no antenna i picked up 0 ap's with the black rubber antenna I picked up two AP's and with the magnetic mount 5.5db I picked up 4 from my driveway all with stronger signal then with the black rummer maid one. Try it and see if it works, mine was about $18 shipped!
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Getting a magmount or permanent mount antenna will be the best and likely only solution to your problem, the trunk is a big metal shell which tends to block RF signals.
    Mar 2003
    Rohnert Park, CA
    i ended up getting a mag mount antenna but because of theft and wire routing issues, ive put it on the rear window deck
    havent tested yet but im expecting a better signal (not as good as outside the car but better)
    even with the rubber duck antenna inside the trunk i picked up 63 APs in the 4 miles i drive to school
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by aoLhaTer
    You really think some geek is going to steal your little 802.11 antenna? I have one (off ebay). I pop it out on demand. I have a Orinoco Gold Classic card w/USB adapter in the glove box connected to the hub.
    I doubt your antenna will work very well in your rear window deck unless it's metal. Most mag mount antennas are "mag" mount for a reason. It needs to be grounded (body metal = ground)
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    My mag mount from fabcorp.com works almost as good in my back seat as it does on the roof. It has 0 degree downtilt so that my have a lot to do with it.
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
    Variable Bitrate cheerio's Avatar
    Jun 2004
    San Antonio
    or a better idea is to buy a cheap car like mine, made out of mostly plastic. Seems to be transparent to most signals . Hell. i live in san antonio, and i can pick up radio stations in Houston, there has to be an explaniation for that one.
    Edit:
    oh yea, to answer your question, i believe radioshack sells signal repeaters. And most WiFi routers now can repeat signals.
    Constant Bitrate chuckctv's Avatar
    Aug 2004
    Virginia
    Look man, i have a full size (all metal) dodge ram 1500 pickup. I bought a mini USB 802.11b unit and ran it in the dash board (inside) at the top toward the front. I get a great signal, if you dont you'll find its probaly the placment of your wireless router inthe home, it needs to be placed near the side of the home as your parking... Also the usb GPS unit can be placed in the same place and works great also..
    Chuck
  1. WiFi FAQ
    By jrtf83 in forum Wireless Communications
    Last Post: 12-30-2009, 07:16 PM
  2. ideas for securing case in trunk?
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 07-09-2006, 06:22 PM
  3. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
  4. some accessory ideas
    By moossmp3 in forum General Hardware Discussion
    Last Post: 09-08-2000, 06:27 PM
