Results 1 to 10 of 19
Thread: Tall Wifi Antenna
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Tall Wifi Antenna
    I'm going to put a 48" Whip antenna on my truck for the CB radio. I don't know much about antenna physics, but I need an antenna for my wifi.
    I know I cant use that because its tuned for CB radio range. Can I get anotehr tall antenna tuned fo wifi that is similar in length? I'd like to have one on each side. thanks.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Mar 2004
    Montreal, Qc.
    VWMAN
    "Live Long And Prosper"
    car: VW Cabriolet '90
    puter: M10000(toasted), Lilliput, CarNetix
    status: In Progress
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Generally speaking , due to the waveleginth - (WiFi has a mutch shorter waveleginth than CB Frequencies) I think it would be rare to find a wIFi of similar leginth. Even the ones listed on that site are 2 ft max. Most CB whip antenna I see are closer to 6....
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    here is some wifi antennas that might interest you,
    I have the 8db omni 20 inch mounted on my car.
    http://www.hyperlinktech.com/web/ant...0_out_omni.php
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Newbie longwoodtrail's Avatar
    May 2004
    Montgomery, AL
    Is it not possible to create a 6ft antena for 2.4ghz range? What I am trying to ask is, is this outside the parameters for WiFi, or do manufacturers simply not make them?
    WTF?!? You did what? With who? Why?
    Current Carputer... 20GB iPod, I am working on an upgrade though!
    FLAC ppgt94's Avatar
    May 2001
    USA
    I got a really nice 9dB wifi antenna from ebay. I think they might be all gone now. The member was Mhzkid or something like that.
    S80
    S80 is offline
    Newbie S80's Avatar
    Aug 2004
    Örnsköldsvik, Sweden
    Ok. Let's see if I remember this correctly!
    The length of an "full length antenna" is determined by the wavelength of the frequency that you will use it for.
    To calculate the wavelength you do something like this:
    Speed Of Light = 299,792,458 meters per second
    Speed Of Light/frequency = wavelength
    299,792,458/2.4GHz = 0.125 meters = 4.9 inch
    So the optimal length for a 2.4GHz antenna should be 4.9 inches or 12.5cm.
    You can also use half length and quarter length antennas. (3.95" or 1.97")
    It was a long while since I did this kind of calculations but I think that they are correct!
    /Niklas
    Aug 2004
    Germany
    but as far as i know you could also make tha antena x * 12,5cm so you can have 25, 50, 100 but an larger antenna means lower signal as said optimal is 12.5
    Golf 3 CarPc Status
    ///////////////50%--------------/
    PSU:Inverter
    GPS:BT GPS
    PC: Slim notebook with 10.4"touch, external DVD.
    Dock for car is in production.
    Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
    S80
    S80 is offline
    Newbie S80's Avatar
    Aug 2004
    Quote Originally Posted by erazor
    Yes, thats right!
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Quote Originally Posted by longwoodtrail
    If you look around, you will find extensive equations on building one from coaxial cable. Different cable means different velocity factors.
    In thoery, you could build an antenna that is 6 foot in length, but you would need an extremely low velocity factor, or an extremely large gain.
    Problems with both: A low velocity factor is going to be pretty hard to find. You would probably end up using something different than coax cable to achieve this.
    An extremely high gain antenna is going to limit your effective range. Look
    around for better explanations of this, but imagine a balloon. An unsqueezed balloon would be your low gain antenna (~3 dB). So so range all around. Now, squeeze it. The sides are much further from the center, but the top and bottom are now much closer. A huge gain antenna is going to have a horrible range outside of directly horizontal to the car.
    Also, the difference in appearance between the CB whip and a rigid WiFi antenna is going to be significant. You are not going to find a whip, it just does not exist.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  1. How good is your Wifi Antenna?
    By Custommx3 in forum Wireless Communications
    Last Post: 03-08-2007, 12:03 PM
  2. Any way to use your car's antenna as a WiFi antenna?
    By NoNonsense in forum Wireless Communications
    Last Post: 07-17-2004, 10:34 AM
  3. Will this wifi card work with antenna?
    By AutoInnovations in forum General MP3Car Discussion
    Last Post: 02-12-2004, 07:49 PM
  4. Anyway to calculate wifi antenna range?
    By bizahh in forum General Hardware Discussion
    Last Post: 01-01-2004, 03:59 PM
  5. Very Small 4 dB WIFI car mount antenna...will it work?
    By AcuraTLFan in forum General Hardware Discussion
    Last Post: 02-07-2003, 12:49 AM
