Results 1 to 10 of 14
Thread: ebay score!
    ebay score!
    I won an orinoco gold 802.11b usb adapter on ebay. They had a picture of the box, in the upper right hand corner I could barely make out the Lucent logo. I paid $22 for it shipped, I just got it, I pulled it apart and sure enough it had a notebook PC Card inside plugged into a USB adapter. The PC card had a plastic plug in the end and underneath was a jack for an external antenna. The person who sold it had 10 of them up on ebay, $9.99 each, I think maybe 5 were sold. the seller is here Need an ocilliscope? How about some radiation detectors?
    Look for the Lucent stuff, the rest doesn't have the adapter or the card with the jack in it. He'll probably list them again.
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Think you can put a different card in it ?
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    I looked it over, the usb adapter is keyed to accept only 16 bit cards so I couldn't try my SMC a/b/g card. I did have an old belkin 16 bit nic card and it fit but it didn't work. I think the pcmcia socket in the adapter isn't set up to pnp/detect any card that you could shove in there, maybe with some driver modification it would work. The card did work by itself without the adapter in my laptop. There are rumors that certian cards can be used to upgrade the usb adapter but since it only accepts 16 bit cards I wonder if it's even worth it. Netstumbler seems to like this card with and without the usb adapter.
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    This thing has a PC Card in it ???
    If so, I guess I should buy one of those
    May 2004
    They also have these.
    I bid one of each
    Even if they are normal stuff, still cheap enough
    That PC Card can go right on my Epia MII motherboard
    Don 944 LA, that's the exact same box mine came in.
    May 2003
    Quote Originally Posted by Don 944 LA
    I bid one of each
    Hey don, did that pc card end up having a antenna port on it, or no?
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by [H]Bugster
    It was Chris that ordered one. Don has just bid on one.
    Installed.
    -GPSSecure- - GPS Tracking
    May 2004
    Must have missed the earlier posts.
    Yes, they do.
    I ended up getting (2) cards and (1) USB setup..
    The cards have the numbers matching the ( Newer ) Gold card. I believe that the USB unit has a (older ) Gold card that is more desireable. But, now that the latest ones have the antenna connects they should be the same card.
    To answer the earlier question YES both of the bare cards I got have antenna connections. I haven't opened the USB one, but I would imagine that it has one cuz the older ones were sought out just for that reason..
    BTW they work great !!!
    May 2004
    Seems like that guy still has a few ....
    check out the link above on the first post..
    he still has (2) PCI cards that have the gold card stuck in them
  1. Ebay GPS (USB type) unit for sale 45
    By bertybassett in forum Classified Archive
    Last Post: 06-15-2004, 12:11 PM
  2. EBAY: Couple of Reverse cameras
    By King_Aero in forum Classified Archive
    Last Post: 04-06-2004, 12:02 AM
  3. is there a new EBAY scam going around?
    By wizardPC in forum Off Topic
    Last Post: 03-05-2004, 02:42 PM
  4. laptop from ebay
    By hijinks21 in forum Off Topic
    Last Post: 01-21-2004, 09:56 PM
  5. Just got this LCD off of ebay... need advice
    By ddt in forum LCD/Display
    Last Post: 02-16-2003, 06:30 PM
