Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Anyone using an 802.11B amp & high gain antenna combo?
    Rochester, NY
    I'm working on putting a computer together for my RV. I plan on putting a high dBi antenna and possibly an amp. Has anyone else done this? I'm talking 12-15 dBi and 500mW to 1W amp combined with an Orinoco Gold card.
    The only problem I forsee is that high dBi omni antennas have a low vertical beam width (8 degrees, such as http://www.hyperlinktech.com/web/hg2415u_pro.php). That means that if I have it raised well above the roof of the RV (which is almost 8 feet) it will be 11+ feet up. If I understand it correctly, I won't get a very good signal with closer APs correct?
    It will be used mostly for picking up distant weak signals so that really shouldn't be much of a problem right? If I do the math out correctly the beam should be at ground level after only a few hundred feet. I want to be picking up signals from at least a mile away. Running 1W on a 15 dBi antenna I should be able to get much farther than that.
    89 Mustang (Autox, road race, and cruiser)
    93 Escort (Daily Driver)
    84 Dolphin RV (Soon to be Carputer Heaven)
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    You should have a "reality range" of around 1/2 mile or more. I have the 8db antenna from hyperlink with 500mw amp with netgear pci wifi card. I have range about 1/8 mile.
    heres a pic
    www.john1701.com/mp3meet2_020.jpg
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Rochester, NY
    That's the antenna I have now. I was disappointed by the lack of range with it. A 12 dBi antenna will be ~3x better than an 8 dBi. Combine that with the 1W amp (with receiving gains of ~17dBi) and I'm hoping to get signals from much father away. We will see...
    Mar 2004
    Fort Myers, Fl
    I have a good range with mine, but I would like to have 1w amp.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Rochester, NY
    I have ordered everything so I will post how it turns out. 40.5" 15 dBi antenna with a 1W amp using an Orinoco Gold card.
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    Since I am in the wi fi hotspot market I gotta say that remember the AP has a role to play in this as well, you may have all the power in the world on your end but if the AP is poorly setup or has poorly placed antenna then no matter what you have, your connection will be lousy
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Aug 2004
    Germany
    damn that stuff iss expensive 700 for the amp^^
    Golf 3 CarPc Status
    ///////////////50%--------------/
    PSU:Inverter
    GPS:BT GPS
    PC: Slim notebook with 10.4"touch, external DVD.
    Dock for car is in production.
    Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
    Mar 2004
    Fort Myers, Fl
    Quote Originally Posted by SAScooby
    if ya wardrivin, you can look for a stronger AP. Plus with 1w amp, he should find quite a few more AP's than I can with a 1/2 w amp.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Rochester, NY
    Quote Originally Posted by erazor
    Uh no. Try $260 (http://www.fab-corp.com). First one on the amp page.
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    What power supply do you plan to use for that thing? Looks like it's 9v...seems to me like for a radio amplifier a clean power source would be essential
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. no high amp alternator?
    By cheerio in forum Power Supplies
    Last Post: 08-24-2004, 04:21 PM
  3. Cell Booster / Amplifier
    By GruvThang in forum General Hardware Discussion
    Last Post: 07-28-2004, 07:35 AM
  4. Replies: 0
    Last Post: 07-27-2004, 12:32 PM
  5. USB 802.11b adapter with external antenna anyone?
    By cyjad in forum General Hardware Discussion
    Last Post: 12-03-2003, 10:07 AM
