Results 1 to 10 of 17
Thread: Any Bluetooth experts here?
    Oct 2003
    Hi,
    Im looking to make my phone connect via bluetooth to the PC, ultimately to use MS dialer so I can make phone calls, effectively use my computer and audio system as a hands free kit.
    Up to Now
    1. I have managed to get the bluetooth dongle (Sitecom CN-500) to work with XP Pro SP2
    2. I have installed and can fully use Nokia PC Suite 4.88 for my phone 6310i
    What I can't do (understand)
    1. Why is there a plethora of new COM devices under Ports (Device Manager)
    Currently 15,16,17,18 - what are these for?
    2. I entered a phone number into dialer and it asked me to configure a modem??????
    3. When in Bluetooth places there is a list of features? for my phone and list of features for my Computer - the only 1 I seem to be able to use is the Headset which makes a stable connection for about 30 seconds then disconnects, this process places the headset icon on my phone
    Is my ultimate goal acheivable or do I need a better phone / different software?
    Any help appreciated as i've been at this for 3 days and only started to get somewhere but nowhere near where I want to be.
    Cheers
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    I've used the built-in XP SP2 drivers, and had no issues.
    IIRC correctly, I installed the dongle, added the bluetooth device, then added a new dial up connection selecting in the modem list something similar to 'bluetooth dial up connection' or 'bluetooth modem' and it did the business.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    rum
    rum is offline
    Newbie rum's Avatar
    Mar 2004
    Wezep, The Netherlands
    You currently make a data-connection to your phone. What you want to do is set up an audio-gateway. The problem is that most phones only accept one bt-connection so when you have an audio-gateway connection you can't control your phone thru a data-connection. This is what I found out with my SE-phones. What I am going to do is to place one of my phones permanently in my carkit which is somewhere out of sight and control my phone with my CarPC using bluetooth.
    Aug 2003
    Warwickshire, UK
    Also SP2 built-in drivers don't have an audio gateway
    Oct 2003
    Quote Originally Posted by stevieg
    Does this allow the computer to work like a headset, you choose to answer / reject a call?
    Also on your phone bill does the call get treated like an ordinairy call or is it a Data call which I presume is more expensive, not sure if these are actually valid questions but when you start talking about Dial up connections it makes we wonder
    Cheers
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    The phone company knows nothing about the bluetooth capability of your phone and if you make a phone call it will not be treated as a data call, regardless of the type of headset you use.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    get phonecontrol
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by SAScooby
    get phonecontrol
    The version I'm using doesn't control the headset ability.. That had to be configured in Windows
    Constant Bitrate Needstorage's Avatar
    May 2004
    Belgium
    Quote Originally Posted by sygad
    Hi,
    Well, I'm sorry to bring you the bad news, but you can't use them both at the same time.
    Because:
    1. Controlling the phone with the pc goes through the Bluetooth Virtual Port. (One of them that are added are reserved for bluetooth SPP profiles)
    2. The headset feature is another Bluetooth profile
    3. a Nokia 6310(i) can only handle one BT connection at a time
    I built my own Phone Control system. I'm using the exact setup like you, Citecom CN-500 BT dongle, Nokia 6310 (not i). My OS is XP Embedded, SP1.
    The Phone Control system controls my phone using the Bluetooth Virtual Serial Port by using the AT commands.
    For handsfree calling I'll be adding a handy-holder that will be connected to the PC audio ports.
    So, forget to be able to totally call and control your phone from your PC all at the same time.
    Needstorage
    Who the hell is general failure?!?
    And what the f@#k is he doing reading my drive C:\?
    Oct 2003
    whoa, BT experts a plenty...now i'm really lost
    Had another play with it last night and managed to create a stable connection to the phone using the audio gateway, off I trundled to MS dialer and tried to make a call to my brother, a little D appeared on my phone (presumably a data call), 5 mins later my brother phoned with "Like, WTF was that ****"....he loves my experimenting really and tries to equally impress me with his demonstration of the F-word as avowel.
    I digress, I will download a copy of that phone control and give it a go, just hate having stuff on my computer that I don't understand or can't configure.
    Stevie-G you said you created a dial up connection and chose the bluetooth modem, I went into my network connections and there was no dial up connection option available, I have Bluetooth connection wizard, network connection wizard, 1394(can't remember)
    Is this defiently right what you did?, if so how the hell do I get my dial up connection option back - any help?
    Cheers for all this, normaly I have half a clue but this one has got me good and proper
    Daz
  1. X10 remote and bluetooth problem
    By liquid_smoke in forum Input Devices
    Last Post: 02-27-2008, 06:51 PM
  2. Lilliput drivers do not install with bluetooth
    By ryguy in forum LCD/Display
    Last Post: 06-12-2004, 11:52 AM
  3. AT&T Cellular Internet Access / Bluetooth
    By ukchris in forum Wireless Communications
    Last Post: 05-27-2004, 10:09 PM
  4. EPIA rebooting! morex 60W and MSI bluetooth dongle?
    By masch in forum General Hardware Discussion
    Last Post: 03-11-2004, 04:08 AM
