Results 1 to 4 of 4
Thread: Infrared extender in car?
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    I have an Audigy 2NX soundcard in my car behind the touchscreen. Is there any way to hook up an IR extender so that I can use the remote control for it? I've seen units like THIS ONE but I was hoping for a smaller, simpler unit since I only have to extend the IR by about a foot.
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Just extend the IR!!!
    Resolder it with longer wires!!
    Mar 2004
    Los Angeles Area
    You mean to open the case, remove the ir receiver, and extend it outside of the case? Hmmm, sounds very intriguing, but what issues would I have to deal with? For example, does the sensor NEED to be behind a plastic filter like it is inside the case and does the cable need to be shielded, etc?
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I've extended multiple IR sensors, some successfully others not. Never done the audigy though. The only real thing that I've found you have to watch out for is overheating the circuits on the board your desoldering the sensor from. I don't think shielding is too important, but it doesn't hurt, Ive also never extended anything over 3ft, but ive seen other people make 15 feet ones for various devices.
    To play it safe, I would just cut away the IR sensor rather then try desoldering it if possible. Then when soldering the new wires on just make sure you don't solder for too long and overheat the circuts. I think the sensor itself can take quite a bit of heat so that shouldn't be a problem, but the circuit board may or may not fry easily depending on the layout and types of chips on it.
    No it will still work even if its not behind a filter. I think the filter is just as much for asthetics then for a practical purpose.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. FS: Car Computer Setup - Everything you need!! Pics Galore
    By EBoundEE in forum Classified Archive
    Last Post: 06-19-2004, 10:41 PM
  4. The melbourne car show
    By magnetik in forum General MP3Car Discussion
    Last Post: 03-13-2002, 06:05 PM
