Results 1 to 6 of 6
Thread: Firewall Limiting Outgoing Ports
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Do any of you happen to know if the firewall that comes with XP SP2 can block all outgoing traffic apart from specific ports? My GPRS connection is free for the major ports but I want to ensure that I do not access any others. I want to limit dial-up connections such that they can only be used to access port 80, 25 etc.
    Chris.
    Newbie John M's Avatar
    Nov 2004
    Milledgeville, GA
    The XP firewall is incoming only. It doesn't do anything to/with outgoing connections at all.
    2005 Subaru Legacy GT
    Status: 40% - starting install
    • AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
    • JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
    Variable Bitrate Dracos's Avatar
    United Kingdom
    Quote Originally Posted by John M
    Incorrect.
    XP DOES stop some outgoing connections, but only the ones from programs/scripts - of which it pops up to tell you its blocking, although it then gives you the option to allow it access.
    Nov 2003
    Massachusetts
    Oh well, time to look into my "other" firewall from Norton then?
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    who is your provider? I had tmobile, and they would limit my ports on the free service.... basically they cant just charge you for accessing something without knowing you'd be charged can they?
    or maybe install httport proxy on your computer to connect to your home computer through port 80, and then you can access any port... it tunnels all access through port 80...
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    ports are useless w/o an app behind them..
    RE: outgoing ports on your own pc... they could only be active when an app on your pc is generating traffic for them.
    Can't you simply control what apps are active and in what way (port usage)?
    •Micke
  1. Need three serial ports on VIA Epia - OK?
    By nxt125 in forum General Hardware Discussion
    Last Post: 01-27-2006, 03:24 PM
  2. limit on com ports?
    By Dragyn in forum General Hardware Discussion
    Last Post: 01-15-2001, 02:32 PM
  3. Additional Serial COM ports?
    By dekodan in forum General Hardware Discussion
    Last Post: 12-03-2000, 05:12 PM
