Results 1 to 10 of 11
Thread: Phonecontrol.net and bluetooth headsets
    Hi,
    I have managed to get Phonecontrol.net working on the home PC interfacing with my Sony Ericsson k700i.
    The question is, can I get that operational, and use my bluetooth headset. I keep trying various combinations of set-up, but nothing works, I can either haev one or the other.
    Can it not be done ???
    Cheers,
    Matt
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Im not sure whether or not you may need to have two bluetooth dongles on your pc...?!?
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    most likely this is because your mobile phone only supports 1 bluetooth connection at a time
    Signature: [==||========] 20% complete
    I think this is the case. Are there other phones that support more than one ?
    Is there a way of routing it through the PC ??
    Thanks,
    Matt
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    i dont think so
    and i dont think so
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    This my not what you want to do, but you could use a USB
    sync cable to connect your phone to PC, then use bluetooth
    to connect headset.
    I haven't done this personaly, here is a guy that managed to
    setup. This post.
    I hope this helps.
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    Quote Originally Posted by Matthew230
    Thanks,
    Matt
    yeah there are phones that support more than one BT connection at a time.
    but if you have one that can only support one at a time (like my v600), then you're out of luck. I dont think there is a workaround.
    Once phonecontrol.net connects to your serial connection through BT, the audio gateway wont be able to connect to your phone at the same time
    Oct 2003
    Vancouver, BC
    I plug in a wired headset for my audio and use BT to connect to the phone's serial port. I don't actually wear the headset, I wired the earpiece to the mic in on the carputer and mounted the Microphone somewhere. I decided to do this cuz I get some crazy noise happening when I use the audio gateway. Almost scared the crap out of me when I first heard it. I'm using Widdcom 3 (tho it says 1.4something in my device manager) and I tried it with a Seimens S55, Moto V80, V600 and a Nokia 6260. Noise with every phone...
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    I think Pocket PC phones with Windows 2003 SE support more thatn one BT connection!!!
    Aug 2004
    On the edge!
    Quote Originally Posted by DjBac
    Yes but they don't and won't work with PhoCo.NET
  1. X10 remote and bluetooth problem
    By liquid_smoke in forum Input Devices
    Last Post: 02-27-2008, 05:51 PM
  2. bluetooth blues :(
    By riddle14 in forum Wireless Communications
    Last Post: 11-18-2004, 05:36 PM
  3. Lilliput drivers do not install with bluetooth
    By ryguy in forum LCD/Display
    Last Post: 06-12-2004, 10:52 AM
  4. AT&T Cellular Internet Access / Bluetooth
    By ukchris in forum Wireless Communications
    Last Post: 05-27-2004, 09:09 PM
