Results 1 to 10 of 17
Thread: Compact Flash WIFI?
    _
    Mar 2004
    Little Elm, Texas
    Compact Flash WIFI?
    I have seen numerous Compact Flash WiFi for PDAs. My question is, do you think they will work in XP?
    Since I am using the MII12000 board I have a compact flash slot and a PCMCIA slot as well. The PCMCIA slot is going to be used by the Sound Blaster Audigy ZX 2 laptop sound card (so that I can have optical out). I'd like to have wireless but it's not critical at this moment. I have a USB wifi key, but it's d-link and it's crap and I don't think I will have an extra USB slot without getting a hub since I will be using a USB rom drive and usb GPS.....
    any ideas? anything other than compact flash and USB maybe? I guess I could look for a shorter than normal PCI wifi card?
    Jan Bennett
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Get a USB Orinoco Gold from Ebay, though it MUST be connected to the board and not through a hub.
    You've got 4 total USB connections on that board. There should have been a cable that came with it that you can plug into the board which gives you the two extra ports.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Jun 2004
    Central California
    @RedGTI:
    I'm not sure whether you are looking for comments by people that use Compact Flash WIFI in general or specific ones that use them with the MII12k. I'll provide you with a comment from the general side.
    I've been using SMC2642W (by SMC Networks) with my laptop for 1.5 years and been very happy with its performance. This is a Compact Flash Type I card. It's inserted into a Compact Flash to PCMCIA adapter to use on my laptop.
    On my carputer I use a Microsoft's USB Wireless NIC. And I have made a side by side comparison (with my laptop in the car) between the two. They both perform about the same way. The signal strength about the same and they lost the connection to my WAP router at about the same time as I was driving away from my house.
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by wizardPC
    nope - no back plate for additional USB ports, the M10000 that I have has the back plate that plugs into two white plugs on teh board and a yellow one for firewire. This board only came with the two USB ports that are on the board below the network connection location....
    honnestly, I don't really feel like having a bunch of USB wires to worry about if at all possible (I'd rather not have wireless than have a USB hub to worry about finding a place for, etc...)
    So, thus the question about the Compact Flash WIFI
    my PCMCIA slot is already taken up by my sound card, so that's not useable...
    Jan Bennett
    Variable Bitrate Bailey's Avatar
    Nov 2004
    NYC
    In for details...
    I had no idea CF can be used as a system device.
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    how/when is CF NOT used for system device?
    •Micke
    Jun 2000
    Nashville
    I just can't imagine a CF WiFi card being very good in the car. I've got a Dell Axim with a CF WiFi card and the darn thing had to be sitting on my dashboard to pick up any AP's with ministumbler. Forget about actually using the internet.
    I just think you oughta forego the whole wifi thing. Oh and for future reference on where your added USB ports are according to the manual:
    I'M DEBT FREE!!
    _
    Mar 2004
    Little Elm, Texas
    I'm sure there was a place to add them, I just haven't throughly read the manual as I've been trying to build the audio system for the past few weeks as that's going to be the most time consuming part of this install.
    I guess I will have to look for a USB plug for this board since the board didn't come with a backplate and the one I have from the M10000 is completely different from what would work for my set-up...
    Jan Bennett
    Nov 2004
    NYC
    Is this some sort of joke?
    _
    Mar 2004
    Little Elm, Texas
    first question: WTF is that?
    second question: WTF does that have to do with this thread?
    Jan Bennett
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. Compact Flash card operating range
    By knubile in forum General Hardware Discussion
    Last Post: 12-23-2004, 03:13 PM
  3. where to get compact flash reader for c137 case?
    By siueclipse in forum General Hardware Discussion
    Last Post: 12-22-2004, 09:45 AM
  4. Cheap Compact Flash
    By BiohazrD in forum General Hardware Discussion
    Last Post: 10-05-2004, 08:07 PM
  5. Compact flash gps compatability question
    By NUIpIsqo in forum GPS
    Last Post: 08-02-2004, 05:48 PM
