Page 21 of 27 FirstFirst ... 1112131415161718192021222324252627 LastLast
Results 201 to 210 of 268
Thread: How to use your VERIZON cell for FREE internet
  1. #201
    Mar 2008
    Quote Originally Posted by blackcobra487 View Post
    Is this trick no longer able to work? I tried to setup my Krzr for use as a modem. I managed to get a connection over 900kbps but when I open the web browser I'm getting a message that says I'm not authorized to use this device for dial-up networking. Is it because my phone defaults to EVDO, as the previous poster stated? I would love if I could get this to work without paying $50 for their tethering plan when I only want to use it occasionally. Any advice guys?
    Hey BC487,
    Well I limited mine to 1x not because it wouldn't connect on EVDO - actually it did - but because I had heard people were pushing their luck connecting that way. In other words, Verizon was watching.
    I think the key for you is the same it was for me; unblocking DUN capability on the phone itself. Now I don't know much about the Razrs - I'm still using my old LG - but in my case all I had to do was use the "administrator" password for my model (found on HowardForums) to access the root menu on the phone and undo what Verizon had done, i.e. unlock dialup networking.
    I did a quick Google search and it looks like it may be a bit more convoluted for you. Check this link out and see if it helps (HowardForums again):
    http://www.howardforums.com/showthread.php?t=1018585
    It seems like you'll need something called QPST, a Qualcomm utility for accessing the hidden configuration menus. There's an indication someone has it up on RapidShare, and I also found a "Hack the Razr" site ("it's your phone ... make it so"), which looks like it has the utility for download. The link for that:
    http://hacktherazr.com/downloads.html
    I'm still connecting tethered, so it's still possible ... The only recurring problem I have is that when I'm connected to my own wireless router at home, every time a page is a little slow in loading the laptop throws up the DUN connection window and I have to cancel it out. Minor price to pay I think when I can have Google Maps up & running in the passenger seat while I'm heading cross country in the Triumph!
    Hope it helps. Good luck!
  2. #202
    Sep 2007
    West Springfield, MA
    What you showed me did help a bit. I can now connect with my phone tethered, which is great. Now I just want to figure out how to keep it from defaulting to 1x. I don't want to get slammed with a huge bill.
  3. #203
    Mar 2008
    Try this one:
    http://www.barnharts.net/bn/krzrk1m.asp
    Again, be really careful if you decide to attempt this stuff - messing up in the root configuration can render the phone useless.
    These guys are interested in disabling EVDO because the phone constantly looking for it apparently drains the battery really quickly on the Razrs. But the result should be the same; the phone should stay on the 1x network even where EVDO is available.
    I should also mention that I think vCast requires EVDO, so if you use that stuff, you may be losing your access to it. That's no big deal to me, but I guess it might be to some.
    Final thought: As I said, I did subscribe to the "MobileWeb" service @ $5 per month. I don't know if it's necessary to connect, but it gives me an excuse for having data minutes show up if Verizon ever does check the details of my usage. It was my understanding - at the time, at least - that they couldn't tell the difference between MobileWeb and DUN use.
  4. #204
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I have a verizon (LG) voyager with the data plan. Can I connect this to my PC (Carputer) for internet?
  5. #205
    Oct 2007
    Verizon For Internet
    BLUTO....is the program you use called qualcomm? Just want to make sure I downloaded the correct software. Would you be able to give me some assistance in setting up the program? If I downloaded the correct software, I have no clue where to even begin with it. I installed the setup files....and I now have the following options....
    Display Caputure
    Dmproxywin
    efs explorer
    factory test mode application.
    gang flash image application
    QCNView
    qpst configuration.
    and well there are a couple of others...but if I have the correct program then you already know the rest of what im looking at. Now I dunno exactly what kind of instructions you have but from what I downloaded there certainly are not any type of details instructions on how to use my verizon cell phone to get my laptop online. Please help. thanks!
  6. #206
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    if this works it would be PERFECT for me as i work till 8pm so i could use it after work and get teh minuites if i were going out after work VERY neat
  7. #207
    Low Bitrate deeznudts's Avatar
    Oct 2007
    Trenton, NJ
    Quote Originally Posted by weso18 View Post
    I used this "how to"to unblock the DUN on my vx8300:
    http://www.howardforums.com/showthre...7&page=1&pp=15
    And now I can get online with no problems. They are good step by step instructions. I had to use QPST_2.7 build 215. I tried an earlier version and it didn't work. All in all it works pretty good. A little slow, but good enough to check email when on the road and get weather updates.
  8. #208
    Oct 2007
    Setting up VZACCESS manager
    Thanks for that info for editing the information on my cell phone. It was easy to follow and it appears to have worked. Now, could you please tell me exactly how the vzaccess manager must be configured for me to get online? Thanks!
  9. #209
    Oct 2007
    Trenton, NJ
    You don't need the vzaccess manager. There's a bunch of info on how to do it in this thread. Here's the skinny:
    -set up your internet connection to dial #777
    username:##########@vzw3g.com (replace # with your phone number)
    Password:vzw
    Thats it, enjoy! I recomend reading up on defaulting to 1x and usage, as verizon could hit you with a monster bill or disable your service.
  10. #210
    Jun 2008
    Is this trick no longer able to work? I tried to setup my Krzr for use as a modem. I managed to get a connection but when I open the web browser I'm getting a message that says I'm not authorized to use this device for dial-up networking. Is it because my phone defaults to EVDO, as the previous poster stated? I would love if I could get this to work without paying $50 for their tethering plan when I only want to use it occasionally. Any advice guys?
    That's right. Now the screen has been updated to offer a way to buy a data plan! My free internet settup with my Razr V3m used to work perfectly, and now this is what I get, so i can only assume that Verizon finally shut the back door to this feature.
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 02:37 PM
  2. GPS to cell phone output somehow ???
    By gadget in forum General MP3Car Discussion
    Last Post: 06-11-2007, 08:22 AM
  3. TDMA cell phone internet access
    By egeekial in forum General Hardware Discussion
    Last Post: 08-05-2004, 04:06 PM
  4. Canadian Co. Cell Phone for Internet
    By syclone477 in forum Wireless Communications
    Last Post: 04-01-2004, 07:06 PM
  5. Garmin Etrex GPS & Verizon CDMA 1xRTT (PC3220) Wireless Card
    By mandiola in forum Classified Archive
    Last Post: 03-17-2004, 12:32 AM
