My ISP will only allow 1 compter (or router) to connect to their server. A hub does not assign 1 IP for all net traffic to the outside, it just tries to pass the data on. If you put your router where your hub is and follow your ISP's instructions for switching to that deviice, I bet everything will work. Then when you get everything sorted out, you can use the hub downstream of the router.
LinkBack URL
About LinkBacks
