Results 1 to 10 of 10
Thread: 802.11G WiFi Adapter -- USB, Cardbus, CF, or RJ45 Ethernet?
    Variable Bitrate Bailey's Avatar
    Nov 2004
    NYC
    802.11G WiFi Adapter -- USB, Cardbus, CF, or Ethernet Bridge?
    Here are some examples:
    Linksys Wireless-G Ethernet Bridge
    Linksys Wireless-G Compact Flash
    Linksys Wireless-G Notebook Adapter (with SpeedBooster)
    Linksys Wireless-G Portable USB Adapter
    I have an MII. So in addition to USB and Ethernet ports, I also have a Cardbus and CF slot that I am not using (PCI can be used for something better). Range and signal strength are important to me (wardriving and whatever...). Also I'd prefer the option for an external antenna.
    I like the idea of not using Cardbus or USB because there are many other devices that could use these ports, whereas only a few can use Cardbus or CF.
    I like the idea of using a wireless bridge, but I hear that this limits features in some wifi software. Can anyone explain?
    I like the idea of using CF, but I don't see one with an external antenna.
    Nov 2004
    NYC
    I just found out the CF cannot be used with Windows, only Pocket PC 2002 and higher?
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    wrong! i have a sandisk 128MB + WIFI card on my laptop
    500Mhz Celeron, 256MB RAM, 20GB Hard drive, Sound Blaster MP3 USB
    Installing in Monte
    1994 Ford Probe SE beater/Girlfriend's car
    1995 Monte Carlo Z34 Engineless carPC
    Nov 2004
    NYC
    Huh? At the same time?
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    Quote Originally Posted by Hcomplyr
    how does that work out for ya.. i was thinkin of getting one of those... how $$ was it?
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
    Nov 2004
    NYC
    Okay, CF is out of the question. Its speed is limited below the 54Mbps spec and it doesn't allow for an external antenna. It's wireless range and strength are questionable also. Great solution for a palm user or something, but not for us.
    The ethernet bridge seems to be the route I'm going to take, if I could just find a good one. I would definitely choose the Linksys but it got a not-so-good review here:
    http://www.tomsnetworking.com/Review...dID-WET54G.php
    Still reading...
    *EDIT: BLOODY HELL! They have to be externally powered!
    I think I'll order a Cardbus and call it a day.
    Nov 2004
    NYC
    Newbie Teknoledgi's Avatar
    Jan 2005
    Gold Coast Australia
    Shuttle XPC
    Don't know where you get one from in the states, but here in Australia, I use a Shuttle XPC wireless network adapter (internal) with an external antenna.
    See link: http://global.shuttle.com/Product/Ac...ec.asp?A_id=34
    I takes up one usb header on your board, so you won't have two ports at the front, but is very neat and fits just behind the rear panel on a morex case.
    Lilliput 8" Touchscreen LCD
    VIA EPIA MII-12000
    60GB 3.5" Hard Drive 5400
    512MB DDR PC2700
    DVD Drive
    802.11G Internal Wireless Card - External 5db Antenna
    100m USB Bluetooth Adapter
    Nokia N70 Phone
    GPS USB Receiver
    Centrafuse 1.6
    Low Bitrate Zharvek's Avatar
    Jan 2005
    Buffalo USB 2.0 54MBPS 802.11G Adapter also has an external antenna port. Works great, I have one myself.
    EDIT: (With an external antenna)
    Nov 2004
    NYC
    So I was over on netstumbler.org reading about how the pro's do it. They convinced me that for a carputer, G is useless. You spend most of your time searching for a signal, not transferring files. In other words: for half the amount of money I could get a better signal using B, but I sacrifice bandwidth. So I went ahead and bought a top of the line wardriving 802.11B cardbus card with antenna jack. When the prices on powerful G cardbus's come down I will grab one.
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. USB 2.0 to ide adapter, anybody got one of these working
    By Batmanatthenewb in forum Input Devices
    Last Post: 08-16-2004, 03:23 AM
  3. Looking for an 802.11B/G USB adapter
    By jhwelsh in forum General Hardware Discussion
    Last Post: 04-20-2004, 01:57 PM
  4. What kind of USB Wifi adapter do you use?
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 01-23-2004, 11:30 AM
  5. Replies: 6
    Last Post: 07-21-2003, 03:18 PM
