http://www.cableco.com/cgi-bin/datapro/1851.html
Not very cheap though.
Hey guys,
Just got a card similar to the pic attached, the connector details are below.
Antenna External detachable dipole antenna (Connector: RP-SMA connector, Cable Length: 94 cm)
Anyone know where I can get hold of an extension cable for it to allow me to run it from the front of the car to the back so I can attach it on the rear parcel shelf???
Cheers
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
Hmmm, may try getting the parts and making my own, the places I've found the cables are like £29 for 2m!
look on netstumbler.org and search for uk- there are a few good uk seller mentioned such as solwise/computerguy etc who will have the connectors etc.
also look across the pond to fab corp/hypertech etc
www.wirelesspro.co.uk/store/catalog/
again not cheap but i think it has to be made out of top quality components.
I hear that it can lose up to 2db a meter so i hope your card has a good amount of volume
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
