Results 1 to 7 of 7
Thread: Mobile Radio Station
    Question Mobile Radio Station
    Have any of you considered (or bought) this?
    http://www.pcs-electronics.com/en/pr...rans#Pci%20max
    I think this would be super-cool for listening to music at work or sharing your tunes with your neighbors and fellow travellers on the highway. Anyone have this or something like it?
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    isnt this the same (well similar) as using a usb fm transmitter?
    Signature: [==||========] 20% complete
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    its a more sophisticated fm transmitter. its pci based and requires an external antenna. also, it broadcast farther than the normal 50-ish feet. usually a couple blocks on factory set power.
    Your everyday carpc geek and tech guru at your service. *bow*
    Elsewhere
    A better, more powerful Mr. Microphone.
    How about the Wiki?
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Q: What is the range of PCI MAX ULTRA?
    A: High power setting will cover the house and a large yard, with good external antenna possibly up to half a mile or more. It should definitely cover one house. With 5W amplifier you are likely to cover from 1 mile to 10 miles, depending on antenna and terrain configuration.
    haha i wonder how far it would be with their 15W amp.. 30 miles?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Jan 2005
    Warren, Ohio, USA
    but also, keep in mind of FCC regulations. ive heard major horror stories from people who stuck on high power amp's for long range broadcasting and got really beat down by the FCC.
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    I have the a NanoFM from this place:
    Techno Lab
    Runs of 12v and audio inputs are RCA, I will use the preamp out from my HU for the source. I extended the antena outside the cab with cable and connectors. The only bad thing about it is the range only goes up to 98.5 so I can't mess with anyone listening to stations higher than that, not that I would.
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. Racist Blacks on Hot 97 (NYC Radio station)
    By pdpbunsen in forum Off Topic
    Last Post: 02-04-2005, 05:05 PM
  3. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 03:38 PM
  4. FM radio Question
    By thepogcbr900rr in forum General Hardware Discussion
    Last Post: 05-09-2004, 07:27 PM
  5. Internet radio. What's your favorite station?
    By carabuser in forum General MP3Car Discussion
    Last Post: 12-11-2003, 11:00 PM
