Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
Thread: Any idea where / if I can solder an external cable to this?
  1. #11
    There wasn't any metal shielding...
  2. #12
    So... where can I get a suitable connector I can wire to a standard coax socket?
  3. #13
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by Arathranar
    It's called a UFL connector. You probably want something like this:
    http://www.mini-box.com/s.nl/sc.8/ca...it.A/id.311/.f
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
  4. #14
    Oh wow, a ready made cable! I really did strike it lucky then!
  5. #15
    Quote Originally Posted by mox
    Is that the exact correct connector? It's hard to tell from the picture. If it is, I'll place an order for the cable and a 5.5dBi antenna form the same site.
  6. #16
    mox
    mox is offline
    Nov 2004
    The Netherlands
    If you look at the pictures of the mini-PCI wifi cards on that page, you can see the same tiny square coaxial connectors as the one on your card. I installed a mini-PCI card in my Toshiba laptop once and recognized your connector right away.
    Software: RR, MM/FD
  7. #17
    That's partly why I'm worried. It looks so like the connector on the circuit board, I'm worried they won't mate.
  8. #18
    ddn
    ddn is offline
    Dec 2004
    It sure looks like its epoxied over in the picture.
  9. #19
    Yeah, I see what you mean. I'll take a look at it tonight. If there is epoxy in there, it's really not much so I should be able to clean it out.
  10. #20
    mox
    mox is offline
    Nov 2004
    The Netherlands
    Epoxy? Your connector looks fine to me, I wouldn't tamper with it. Just order the pigtail, things will mate just fine. The pcb connector is male, the pigtail is female.
    Software: RR, MM/FD
  1. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 03:45 PM
  2. Replies: 11
    Last Post: 12-06-2004, 03:48 PM
  3. Lilliput and ribbon cable problems
    By Udonboy in forum LCD/Display
    Last Post: 11-08-2004, 07:24 PM
  4. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 12:25 AM
  5. Cat6 cable -> IDE Cable
    By dan0myte in forum General Hardware Discussion
    Last Post: 08-31-2001, 08:29 AM
