Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Any idea where / if I can solder an external cable to this?
  1. #21
    Nov 2004
  2. #22
    Quote Originally Posted by Arathranar
    Yeah, I see what you mean. I'll take a look at it tonight. If there is epoxy in there, it's really not much so I should be able to clean it out.
    No epoxy there. It's clean as a whistle. Must have been an artifact from the flash.
  3. #23
    Quote Originally Posted by mox
    It's called a UFL connector. You probably want something like this:
    http://www.mini-box.com/s.nl/sc.8/ca...it.A/id.311/.f
    Dammit. There's also a 'straight' as opposed to the above 'reverse polarity' version of this cable. Which do I want? What's the difference?
  4. #24
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    *shrug*
    Just focus on the text: "Designed for mini-PCI cards", stop worrying and proceed to checkout
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
  5. #25
    mox
    mox is offline
    Nov 2004
    The Netherlands
    http://wimo.de/cgi-bin/verteiler.pl?url=wlan_cn_e.htm
    "Reverse polarity" refers to the connector, not the cable.
    Hope this helps
    Software: RR, MM/FD
  6. #26
    Hope this helps
    I think so. I read it as saying 'if they connect, your fine'.
    I bought the cable and aerial. Inside the car (it's a very short cable) it makes no obvious difference to the signal strength or quality .
  7. #27
    Nov 2004
    Northern VA
    The connector could be diabled in the firmware.
  8. #28
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    no you need to move the cap that i've outlined in the pic, the antenna connecter is disconnected because the internal antenna is connected
    you might just try bridging the 2 pads
    肚子笑痛了
    S60 Install
  9. #29
    I was wondering how I would switch the two if it was disconnected in the hardware. So you're suggesting I just connect the two metal ends of the rectangular component? Or are you suggesting I connect the bottom end of the rectangular to the blob of what looks like just solder to the upper right?
  10. #30
    May 2003
    Miami, FL
    first I would try just bridging the two pads that i've outlined in this pic, and if that doesnt help then you will have to move the cap (the cap is outlined in the first pic) so that it lines up with the red square
    肚子笑痛了
    S60 Install
  1. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 03:45 PM
  2. Replies: 11
    Last Post: 12-06-2004, 03:48 PM
  3. Lilliput and ribbon cable problems
    By Udonboy in forum LCD/Display
    Last Post: 11-08-2004, 07:24 PM
  4. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 12:25 AM
  5. Cat6 cable -> IDE Cable
    By dan0myte in forum General Hardware Discussion
    Last Post: 08-31-2001, 08:29 AM
