Results 1 to 6 of 6
Thread: serial connection
    Mar 2005
    serial connection
    I'm following http://315.fiberworld.nl/d500/ guide and when I try to make a new connection in New Connections wizard I get an error....
    It was working a little while ago and I don't know if I've done something to stop it from working.
    Raw Wave
    Jun 2004
    On the beach
    Try a reboot, also ensure that the RAS Services are started under Services in Computer Management - I'm guessing you are using XP. Check the Event Logs for errors
    Mar 2005
    I cannot find RAS in Services. If I try and start routing and Remote Access from in Services I get the the error above.
    checked my log and found:
    The Routing and Remote Access service terminated with service-specific error 2147483720 (0x80000048)
    Checked MS site but they have no info.
    Raw Wave
    Jun 2004
    On the beach
    Have you changed anything recently on it?? Try System restore or run sfc /scannow to see which files are the incorrect versions.
    Mar 2005
    I have System Restore turned off and sfc /scannow didn't find anything.
    Mar 2005
    Ok done it. I think there is a problem with the new WIDCOM drivers or the patched files, BT software is telling me that it cannot find any BT device and I cannot use the setup wizard because it again tells me that I have no BT device or it isn't pluged in properly.
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
  3. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 12:49 PM
  4. USB to serial
    By Sleeka in forum General Hardware Discussion
    Last Post: 12-24-2002, 04:55 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
