Results 1 to 10 of 13
Thread: looking for a roof mount for a linksys type antenna..
    bmo
    bmo is offline
    Low Bitrate bmo's Avatar
    Feb 2005
    ohio
    I have a wmp54g pci card and bought a HGA7S 7.5db gain antenna that just screws right into the pci card.
    I am getting good links driving around but was looking to make the antenna external. I have a F150 and don't mind mounting the antenna on the roof.
    I searched for mounts but came up with really nothing... The closest I have seen was panel mount sma connectors. I'm not to sure how they would fair in weather thou.
    Also maybe a 6 foot extention cable for the mount.
    Thanks for any info...
    Bmo
    Low Bitrate GRod's Avatar
    Aug 2003
    San Diego
    Check out these guys. I'm doing something similar with an EVDO card (and also on a F150 ).
    Antenna
    http://www.wpsantennas.com/index.asp...PROD&ProdID=34
    Connector Cable
    http://www.wpsantennas.com/index.asp...TS&Category=47
    GRod
    Carputer/AV System ~95% complete
    Parts all acquired - testing underway
    Fabrication and integration underway
    More on my Ride
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    but thats for a cellphone, operates on 806-894MHz & 1850-1990MHz .... i mean correct me if im wrong, im a bit of a wifi noob but wouldnt a 2.4Ghz (2400Mhz) antenna be what you need?
    Oct 1999
    Quote Originally Posted by GRod
    Antenna
    Connector Cable
    GRod
    Why are you offering a cell antenna? He needs a wifi antenna. There differnet you know.
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    george_hardesty (uid) on ebay has what you are looking for for 1/5th the price most retailers charge.
    or you can go to the good folks at
    http://www.radiolabs.com/products/an....4-mobile7.php
    and spend quite a bit more for the same thing but get one that is metal and shiny (arguably better build quality but same functionality).
    Welcome, cdm.
    You last visited: 09-13-2006 at 02:42 AM
    Private Messages: Unread 0, Total 3.
    Wow.. how things have changed in 4 years. Gone are the days of mcgyver and datalux
    Registered User
    Oct 1999
    Quote Originally Posted by cdm
    Nice!
    bmo
    bmo is offline
    Feb 2005
    ohio
    Well I have been searching around and talkin to some people at a local ham radio shop and ordered some pretty cool stuff.
    I am going with a roof mounted nmo 3/4 style mount(I love to drill holes in roofs). Then using LMR-400 cable, it's a very low loss cable. About 1/2" thick, the stuff makes rg6 look like primary wire. To a rp-sma male connector that connects to the lynksys card. And the antenna is from hyperlink, HG2403U-NMO.
    I think overall its probaly way overkill, but what the heck.
    I'll let you all know how it works.
    Bmo
    Oct 1999
    Quote Originally Posted by bmo
    Bmo
    Why not get a trunk lip. You dont have to drill for those and there grounded.
    bmo
    bmo is offline
    Feb 2005
    ohio
    I don't have a trunk...
    Anyways It's a done deal LOL... I mounted the nmo yesterday. I don't mind having it mounted like that. Kind of geeky cool I guess.
    Bmo
    bmo
    bmo is offline
    Feb 2005
    ohio
    Just an update on the antenna...
    With the setup that I posted before I have great signal and great snr. It works better that I thought it would. Almost trippled the range when I just had my linksys antenna plugged in the card. When using Netstubbler I pick up double the amount of ap's.
    So if your looking for a good setup for your moble wireless I would recommend this setup...
    Bmo
  1. USB 2.0 Linksys WUSB54G - Antenna Hack
    By mbkowns in forum Wireless Communications
    Last Post: 06-23-2006, 06:02 PM
  2. F/S: Linksys Wireless G USB Receiver with moded Antenna
    By LESLIEx317537 in forum Classified Archive
    Last Post: 11-19-2005, 08:56 PM
  3. Through glass mount wifi antenna
    By n8scstm in forum General Hardware Discussion
    Last Post: 01-31-2005, 09:11 PM
  4. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  5. would a omni ceiling mount antenna work in my trunk?
    By aoLhaTer in forum Wireless Communications
    Last Post: 07-14-2004, 03:33 AM
