Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Hidden wifi antenna... what would work better?
  1. #11
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    The higher the gain, the flatter the lobes become in the vertical direction. If you're down in a valley and you're trying to talk to an access point on a hilltop and you've got a very high-gain antenna, it won't work well. But as long as the access point is on the same plane as you, it'll work great.
    Not sure how the stub antennas are made...
  2. #12
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Mine is mounted upside down on the bottom of the parcel shelf in the hatchback area. Signal sucks. I need to get an extension cable and mount it vertically on top of the shelf.
    Want to:
  3. #13
    FLAC -zip-'s Avatar
    Ontario/Canada
    Have an orinoco gold card on order. Was thinking of putting the antenna on the trunk.
    So are you saying if you have a spoiler there is no point? Also the car is tinted would that block the signal as well?
    Sound Stage
    Eclipse|MTX|Infinity
  4. #14
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If the spoiler is fiberglass or plastic, it shouldn't cause a problem. Some types of window tints can block the signal, but that's pretty easy to test. Just try it with the windows up and then down.
    Want to:
  5. #15
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Bugbyte
    Metallic tints block signal. The cheap ones are usually metallic. Ceramic window tints will let the signals through. Lots of people on the GS forum were having weird problems after getting their rear windows tinted, like they were driving over water
  6. #16
    May 2005
    was the thing u seen on mtv like this,
    http://cgi.ebay.de/ws/eBayISAPI.dll?...ayphotohosting
  7. #17
    Phone Control Moderator Chaos_666's Avatar
    Oct 2004
    Germany
    Hi there
    Just found this site on the net. Think i´m gonna try this antenna in my car
    http://wireless.pollaknet.at/index.p...=antennen/omni
    THX
    Chaos
  8. #18
    FLAC -zip-'s Avatar
    Ontario/Canada
    Update: on the trunk is perfect the antenna is very small I can pick up signals a LOOOOOONG way away.
    When I first looked at the pictures here I thought the damn antenna was gonna be huge, its only like 5 inches tall.
    Sound Stage
  9. #19
    Constant Bitrate John_Duh's Avatar
    Feb 2005
    Belgium
    hey TheJack, this is just an idea i've been playing with :
    How about mounting the antenna in the 3rd brake light. You could use 'type 1' and skip the metal base since the roof of the car would act as base.
    Please post your findings since i'll have the same car and the same options
    '02 Toyota Celica TS
    Carputer progress : [#######---]
    Currently working on : software ...
    Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
    Parts needed: USB wifi dongle (with external antenna)
  10. #20
    Variable Bitrate fuctup's Avatar
    Nov 2004
    Minneapolis
    try a mini sector antenna, or replace you radio antenna with a 2.4ghz
  1. any one used the Terk TV55 Antenna
    By lawrence in forum General Hardware Discussion
    Last Post: 08-31-2004, 07:06 PM
  2. Cell Booster / Amplifier
    By GruvThang in forum General Hardware Discussion
    Last Post: 07-28-2004, 06:35 AM
  3. Any way to use your car's antenna as a WiFi antenna?
    By NoNonsense in forum Wireless Communications
    Last Post: 07-17-2004, 09:34 AM
  4. would a omni ceiling mount antenna work in my trunk?
    By aoLhaTer in forum Wireless Communications
    Last Post: 07-14-2004, 02:33 AM
  5. Anyway to calculate wifi antenna range?
    By bizahh in forum General Hardware Discussion
    Last Post: 01-01-2004, 02:59 PM
