Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: $5 DYI antenna?
  1. #11
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    No, you can bend it. Its just stiff. But between an amplifier and an antenna that are both permanently mounted somewhere, go as big as you can afford. Again, the bigger you go, the less flexible, but also less loss.
    Here's a calculator I use:
    http://www.timesmicrowave.com/cgi-bin/calculate.pl
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  2. #12
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    by reverse are you sure its not reverse polarity sma?......make sure you have your polaritys right or the antenna wont do you any good
    PC Components:
    My work log
  3. #13
    Variable Bitrate lastberserker's Avatar
    Apr 2005
    Seattle
    Quote Originally Posted by kiltjim
    Very cool calculator!
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
  4. #14
    Apr 2005
    Seattle
    Quote Originally Posted by Peoples
    Here is the product. I cannot tell better, can you?
  5. #15
    Dec 2004
    Los Angeles, CA
    I'd buy one if someone decides to start the making lol
  6. #16
    Feb 2004
    PA, USA
    Ok. From the datasheet, the antenna output is reverse polarity SMA. Just make sure that if you are going to make your own cables you get the right ends. You can get any cable, just make sure you get RP-SMA plugs.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  7. #17
    Apr 2005
    Seattle
    Update: I returned SR-238 connector to RS and ordered proper N-type from eBay. When both Hawking's amp and connector are here I'll get some good cable and solder that "spider omni"
    Now two questions: how do I test this antenna's gain? And is there some place to buy a small plastic dome that is transparent to 2.4GHz? Something that will look cool alongside that Rayming MR-350 GPS unit
  1. Replies: 7
    Last Post: 03-04-2008, 11:16 PM
  2. Using Radio Antenna for GPS
    By phita23 in forum Newbie
    Last Post: 03-27-2005, 01:42 PM
  3. lengthening fm transmittor antenna wire
    By hand in forum General Hardware Discussion
    Last Post: 03-24-2005, 11:21 PM
  4. 2.4 GHz Mobile Antenex Antenna
    By Mrbmw99 in forum Wireless Communications
    Last Post: 01-18-2005, 01:49 AM
  5. Question Regarding Power Antenna
    By temposs in forum Newbie
    Last Post: 11-13-2004, 08:14 PM
