Results 1 to 8 of 8
Thread: What would you say is the ultimate wifi setup?
    May 2005
    NORWAY
    Hi!
    Im currently planning a wifi setup for my car.
    But i want some tips and advice from you guys.
    Simply:
    What would you say is the ultimate wifi setup in your car?
    Everthing from usb/pcmcia/pci cards, antennas, best looking antenna, hiden antenna vs big antenna etc....
    Registered User
    Oct 1999
    If you have room for a full hight pci card then grab an 802.11g card. If you dont have alot of room (like me) then definitly go with a usb 802.11g adaptor. With the adaptor you can keep the system small and the adaptor can be pulled out quickly if needed. The usb one you can also make a nice cheap directional antenna out of a wire mesh strainer.
    The land of polar bears and nekkid blonds
    It's probably not the ultimate solution, but it'll be good enough for me....
    PCMCIA Card:
    http://www.zyxel.com/product/model.p...lue=1021876859
    Antenna:
    Antenna
    I thought about doing a pcmcia card but the usb ones just seem easyer and end up giving you a cheaper sultion if space is a big concern.
    Here is a link to the DIY cookware antennas for the usb adaptors.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    My PCI WiFi card causes the processor to go 100% every 2-3 minutes and you get a skip in the music. How do I know? Because when you remove it, there's no skips or processor spikes. The USB ones don't cause that problem.
    Want to:
    FLAC -zip-'s Avatar
    Ontario/Canada
    Same with PC Card/PCMCIA Wifi adapters, they make my music crackle when trying to connect.
    USB seems the way to go
    Sound Stage
    Eclipse|MTX|Infinity
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    I have :
    Orinocco Gold 80211.b PCMCIA ( on epia MII slot )
    Airlink USB 80211.g dongle
    I can use one or both through WinC which I have on a tab in CentraFuse.
    They both have their pros/cons..
    Don
  1. The Ultimate Project
    By WRX2001 in forum Newbie
    Last Post: 01-14-2005, 07:47 PM
  2. Ok setup? What Power supply?
    By untal3nted1 in forum General Hardware Discussion
    Last Post: 01-01-2005, 06:17 PM
  3. help with my wifi setup?
    By ŠuTcH in forum Wireless Communications
    Last Post: 12-05-2004, 11:10 PM
  4. Renault Laguna Puter Setup check
    By Noctris in forum Newbie
    Last Post: 05-24-2004, 05:05 AM
  5. Replies: 12
    Last Post: 02-26-2002, 01:01 AM
