Results 1 to 7 of 7
Thread: Has anyone tried this AM/FM reciever
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    I am thinking about getting this AM/FM reciever but can not find any users with it. Does anybody have one? I have not heard of any other AM/FM reciever other than the radio shark which I can not find any good results.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    looks like the D-link or gemtek radios to me. Only with a serial interface (which would help with the USB driver problems coming out of hibernation)
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Do a search, the Radioman AM/FM has been discussed many times here. I have one, and it performs poorly just like the others.
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Well, here's a problem I see right off the bat... Is it XP compatible? Look at the page. Win3.1-Win95.
    Peace,
    Rafster
    Mar 2004
    Redondo Beach, CA
    It's a serial radio and will work under any operating system. The supplied software also works under XP but you probably wouldn't want it in a car. If you want to write your own SW, do a search in the forums. The protocol was reverse engineered and posted way way back.
    Oct 2003
    SOCAL
    rando
    What antenna did you use? Have you tried it with the stock vehicle antenna?
    Mar 2004
    Redondo Beach, CA
    I tried the supplied antenna and my stock 4runner antenna. Either way, it performed poorly. The problem isn't the ability of the tuner to pull in a signal. It did that adequately. It's the ability of the tuner to filter out adjacent channel noise, spurious RF noise from your alternator, HV power lines, the sun, and the various switch mode power supplies floating around your car PC -- all of which change rapidly while in motion. To put it simply, these tuners were not designed to perform well in a mobile automotive environment.
    Automotive grade radio tuner and signal processing circuitry contain significant technology to combat these problems. If you do a bit of checking in the forums you'll find that all of the 'PC' radios perform similarly poor. For now, it seems our only hope is one of the open hardware radio projects (see forum FAQ) being developed by several members here. These projects all rely on automotive grade tuner and signal processing components and have already demonstrated markedly better performance than any of the PC radios. None of them are available for purchase yet.
  1. Earthmate GPS reciever question
    By glebreck in forum GPS
    Last Post: 04-19-2005, 10:06 AM
  2. Replies: 12
    Last Post: 03-27-2005, 09:07 PM
  3. Replies: 3
    Last Post: 01-30-2005, 01:13 PM
  4. ps2 pelican remote w/ creative reciever & girder
    By ShinkunoNamida in forum Input Devices
    Last Post: 04-26-2003, 02:00 PM
  5. AM/FM radio
    By ShinkunoNamida in forum General Hardware Discussion
    Last Post: 05-15-2002, 08:40 PM
