Results 1 to 10 of 10
Thread: USB 802.11g adapters?
    I need to know if any one uses a usb 802.11g wifi adapter and if so dose it work with netstumbler under windows 2k?
    I posted a message over there and basicly they have what I would consider some **** tard admins. This is what they said "If it isn't on the suported list it may or may not work".
    So what I'm lookiong for is confirmed usb adaptors (preferably pen drive shaped) that you guys have found to work with net stumbler.
    Jan 2005
    i use one with XP and it should work with 2k as it loads ndis drivers also like XP
    I have heard that win2k shiped with ndis 1.0 and xp has 1.1 or at least that is what some nazie over at the netstumbler forums was yelling about.
    What usb adaptor do you have?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    I have used a Microsoft USB G adapter with Windows 2000, netstumbler worked perfectly
    Nov 2003
    to be honest with you i haven't encountered one yet that has issues with the latest version in 98SE, ME, 2000 or XP. i've even had some crappy generic ones pick up networks from the get-go
    Quote Originally Posted by Hcomplyr
    With netstumbler? I know any of them will work for normal 802.11g networking but working with netstumbler is a whoal nother deal.
    I looked up the microsoft one. It is a little big for what I need it for. I could probably squeeze it in but woulden't leave much room.
    Low Bitrate Zharvek's Avatar
    Jan 2005
    I use the Buffalo USB254G wireless adapter. It also has an external antenna support. I use an antenna and network stumbler all the time. Works great.
    Thanks for the info. Is this the one you have? If so it is kind of big for what I need. Of corse I have never seen the insides of one but maby it could be slimed down a good bit.
    Jan 2005
    Yeah thats the one, that picture gives no justice to size. lol
    Its quite small actually. Maybe not small enough for some of the installs going around here, but its nice behind my arm rest in the rear seat.
    W4.8 x H3.7 x D2.2in (120 x 92 x 56mm)
    Yea it is a bit big for what I need. It is a good option though if I mounted it some place else. How is the reception on it? The existing dlink card I have sucks badly. I cant connect to it with my laptop sitting a foot away from it in the car.
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. 802.11G WiFi Adapter -- USB, Cardbus, CF, or RJ45 Ethernet?
    By Bailey in forum Wireless Communications
    Last Post: 01-22-2005, 12:33 PM
  4. Exist? 802.11G USB Adapter with SMA connector.
    By TheJack in forum Wireless Communications
    Last Post: 09-10-2004, 12:05 PM
  5. Serial to USB adapters / IRman
    By Maveric in forum General Hardware Discussion
    Last Post: 04-18-2002, 07:47 PM
