Results 1 to 3 of 3
Thread: wwan(wireless wide area network)-portable hotspot. MUST READ
    Constant Bitrate lominono's Avatar
    May 2005
    i did a quick search in these forums and didnt come across this so ill post.
    okay i was reading through a cell phone forum and came across this:
    its a wwan(wireless wide area network) box(you have to make it yourself though). its a box you plug into the cigg port and it automatically logs into verizons evdo(broadband access) network. you then connect your device to it and you have a mobile hotspot.
    sounds like it could be very very usefull in a carputer setup.
    Jan 2004
    Wow, that is awesome. I've gotta learn Linux.
    Bruno Speech Recognition - Advanced Speech Recognition designed to control any program. Extra support for FrodoPlayer and Winamp.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    You could do the same with a CarPC that has a PCMCIA port and an ethernet port, plus a wireless access point.
    Basically, get the VZW card, and get some sort of PCMCIA port. Get the card running with your PC. If you have XP, turn on the Internet Connection sharing with your wired ethernet port. Go to the properties of the VZW connection and go to Advanced, and click 'Share this connection'.
    Get a crossover cable and a WiFi access point (not a router, just an access point), and connect from the ethernet port to the access point. Voila!
    I'll probably do something like this. Not to mention working a 10/100 hub into the car. Just for those random in-car LAN games.
  1. "Audio" in Light skin: wide playlist area and no AVS
    By swissRv in forum NeoCar Media Center
    Last Post: 12-09-2004, 09:34 AM
  2. Peugeot "VAN" - Vehicle Area Network
    By Jamez_Warner in forum General Hardware Discussion
    Last Post: 05-05-2004, 10:46 PM
  3. Replies: 4
    Last Post: 03-16-2002, 01:32 AM
  4. Replies: 1
    Last Post: 06-13-2001, 09:43 AM
