Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Cingular wireless woes. I'm being told Media net is wrong plan for internet
  1. #11
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Here's a good thread that also includes the settings you need:
    http://www.howardforums.com/showthread.php?t=624142
    Z
  2. #12
    FLAC J187's Avatar
    Nov 2004
    Boston
    Thanks Zogg. THat's the light I needed Shed. Good INfo. I don't need much, only a once-in-while decent connection. Thanks again
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  3. #13
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Great info, a big thank you from me as well!
  4. #14
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    Quote Originally Posted by dmurray14
    ^ Wrong.
    Why?
    Welcome, cdm.
    You last visited: 09-13-2006 at 02:42 AM
    Private Messages: Unread 0, Total 3.
    Wow.. how things have changed in 4 years. Gone are the days of mcgyver and datalux
  5. #15
    Oct 2004
    Quote Originally Posted by Zogg
    Z
    The instructions from that thread work very well. Time to give Cingular some more money.
    Does anyone know if I can use the two other (EDGE) profiles that the Cingular Connection Manager created as well? I believe the EDGE provides much faster speeds.. Thanks.
  6. #16
    Apr 2005
    Plano, TX
    I've always used the Sony Ericsson connection software instead of Cingular's CM so I don't know for sure what those different profiles do. My understanding is that if you are using an EDGE-capable phone then it automatically tries to use it over GPRS. But there is one thing to look out for.
    If you have Media Net or Media Works (the old name) then you MUST use wap.cingular as the access point, and NOT use isp.cingular. isp.cingular is the access point for the Data Connect plans, and if you use it mistakenly you may rack up data charges.
    So check that 'EDGE/GPRS Accelerated' profile and make sure it isn't using isp.cingular.
    Z
  7. #17
    Oct 2004
    Ok great, thanks for clearing that up. I thought it was something along those lines; the other two profiles do use isp.cingular, so I will stay away from those. I thought it was weird that it created those automatically.
    Thanks again.
  8. #18
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    Z
    If you have unlimited data then why not use isp.cingular.com ... becuase if they try to give you crap later you can just say I am on the unlimited plan so sue me .. lol
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  9. #19
    Apr 2005
    Plano, TX
    Why pull the tail of a tiger?
    If you use isp.cingular on the wrong plan then you WILL rack up data charges and you WILL have to call to get them removed (hopefully), and you might have to explain how you came to get them and cause more problems. isp.cingular is not programmed into Cingular's phones, wap.cingular is, so if you try to use isp.cingular then you have to be intentionally doing something they don't want you to do.
    Better to not repeat the mistakes of others.
    Z
  10. #20
    FLAC J187's Avatar
    Nov 2004
    Boston
    Not to mention that just because you are on an unlimited plan which allows for WML browsing, doesn't mean you aren't liable for accessing full fledged web regardless of how you do it.
    Please help.
