Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: D-link usb wifi issues?
  1. #11
    FLAC djmickyg's Avatar
    Feb 2004
    it works not using the windows auto connect but i cant get winc to work??
    it wont make an ip in winc and wont connect?
    do i have to turn off the windows auto connect for it to work?
  2. #12
    Belgium - Oostmalle
    The D-Link util is more easy toget a connection with, so it's best not to let WinXP configure your wifi. Do you have some sort of firewall installed in your car? If this is the case, you have to tell it that your home network can be trusted, otherwise you won't be able to connect to your home network...
    Car : Hyundai Tucson
    Carpc :
    Lilliput 7" touchscreen indash 90% done
    PSU : M2-ATX
    Epia M10K /512DDR/80GB Maxtor
    Software : Windows XP Pro 100% done
    RR with DigitalFX skin
    In car : 80% done
  3. #13
    Feb 2004
    ive got the xp firewall on only... if i turned it off that might help?
  4. #14
    May 2005
    Woodstock, GA
    Quote Originally Posted by djmickyg
    no reason to have it in the car.
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
  5. #15
    Belgium - Oostmalle
    Normally XP's firewall doesn't block a home network, but you can disable it to have a try.
    Carpc :
    PSU : M2-ATX
    In car : 80% done
  6. #16
    What dlink usb card do u have?
  7. #17
    Feb 2004
    the grey one with the flip up dark grey antenna.. dont know the model
  8. #18
    Ahh I know the one you are talking about. It is weird that that one is giving you problems. From what I heard that is one of the more compatable ones. One of these days I will find a usb stick type that some one can confirm to work with netstumbler.
  9. #19
    Jun 2005
    Sweden
    Quote Originally Posted by hcker2000
    I have the Netgear WG111 (not sure if it's the V2 or not S/N starting with WG72... and FCC ID: PY3WG111V2) and I can confirm that it's working with netstubler 0.4.0
    But on the other hand I get very low connection speed running on the 11b network to my D-link AP. Topspeed has been at 10K/s...
    Trying to sort it out... But it do work with Netstumbler.
    /Zappa
    Carputer status:
    Collecting pieces: 75%
    Installation: 0%
    Biketourist.com - No carputer stuff on the site yet..
  10. #20
    Thanks for the info. I have a dlink nick in my car pc and as far as I'm concerned it was over priced for what it is.
    I can't even connect 1-2feet away from the thing with my laptop. Oh well its taking up far to much space any way.
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 09:26 AM
  2. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  3. USB 2.0 issues PLEASE HELP!
    By Kamakazie2 in forum General Hardware Discussion
    Last Post: 10-23-2006, 07:25 AM
  4. What USB Wifi to buy?(UK)
    By vintageb3 in forum Wireless Communications
    Last Post: 01-17-2005, 06:02 PM
  5. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 01:50 AM
