Results 1 to 10 of 20
Thread: D-link usb wifi issues?
    FLAC djmickyg's Avatar
    Feb 2004
    Exclamation D-link usb wifi issues?
    ive got a new dlink usb wifi thingy.. and it works all good on my desktop pc but in the car it has an error in the system tray? and when i try and repair the connection it wont do it..
    ive used winc and it recognises it but it wont create and ip when trying to connect, even when connecting to my own wireless network
    im running win xp.. the services are all as the should be.. (i put them all back hoping it would fix it)
    and i dont think ive taken anything else out of windows
    May 2005
    Woodstock, GA
    Well, for one It does'nt "create" an IP. I assume youre trying to use use a Dynamic adress? Make sure your DHCP client is enabled, also Check your TCP/IP settings for automatic address.
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
    Feb 2004
    sorry can u explain the dhcp client thingy??
    the tci/ip is all set to automatic
    also i have disabled the inboard lan card.
    thanks
    May 2005
    Woodstock, GA
    Quote Originally Posted by djmickyg
    thanks
    DHCP. If you dont know the ins and outs of TCP/IP, now would be a good time to learn.
    Banned
    May 2005
    Since the WiFi is USB based are your other devices that are installed on the USB hub working? I would go in and nuke the USB Hub from Device Manager and the WiFi drivers if there are any installed. Then just reboot and see if Windows XP does an autodetect and sees the USB Hub . If so it will prompt for the drviers from the original Windows XP CD so make sure you have it handy.
    Then if there are additional drivers needed for the USB WiFi device install them after the hub has been reinstalled.
    Feb 2004
    it isn't running from the usb hub, its directly in the pc's usb port
    May 2005
    Woodstock, GA
    What operating system are you running?
    Feb 2004
    xp sp2
    Feb 2004
    ok ive managed to do something, cus im typing this from the car..
    i was running frodo as the shell and when i turned it back to explorer it started to work?
    May 2005
    Woodstock, GA
    Hmmm... Dounno. Havent tried running frodo as shell yet.
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 09:26 AM
  2. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  3. USB 2.0 issues PLEASE HELP!
    By Kamakazie2 in forum General Hardware Discussion
    Last Post: 10-23-2006, 07:25 AM
  4. What USB Wifi to buy?(UK)
    By vintageb3 in forum Wireless Communications
    Last Post: 01-17-2005, 06:02 PM
  5. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 01:50 AM
