Results 1 to 10 of 13
Thread: How to extend antenna from your wifi PCI card?
    Dec 2003
    Has anyone had any experience extending the antenna from a PCI wifi card? I have Linksys dual band PCI card. I was thinking about cutting and extending the wire from the antenna and the box, but im not sure if this is the "correct" way. Heres a pic of what it looks like:
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Sure.... you can do that.
    Just get the cable and the right connector and you all set.
    The pic is from my usb adpter mod......
    Dec 2003
    what type of cable should I be using and which connector?
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    Well take a look at your card, you should be able to unscrew your antenna, and there is a connector there. You can buy antennas for ~30$ in electronic/computer stores.
    Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
    Trunk fiberglassing in progress...
    Need GPS / Aux Input / WiFi
    My Corolla Computer
    Dec 2003
    there is no way to unscrew the antenna, I can take the antenna off the board but it is still attached to that little black wire.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Tred
    You can add a connector onto the card, adn get an appropriate antenna and cable. Soldering a cable to the wire might be tricky, and you will have to make sure you have an adequate strain relief.
    If your not good with a soldering iron, get a different card with a connector so that you can easily attach an external antenna.
    Michael
    Dec 2003
    I can solder, what connector, cable, and antenna do you reccomend?
    Jan 2005
    You cant just extend that wire willy nilly though or you will get a huge loss in signal over it. A much better idea would be to get a usb one so you can position it well in the first place.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    or just pull the metal can off , the antenna cable should connect with a small conector to the board. Then just find a suitable replacement antenna with that connector.
    肚子笑痛了
    S60 Install
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    There are many types of each that you can look into getting. Some of the low loss connectors are SMA and N connectors. SMA is generaly smaller, but might be harder to work with. As for cable, the thicker the better for signal loss, but the harder to run to your antenna. The thinner, the more loss, but easier to run. It would depend on your lenth of run. Under say, 6 feet, RG213 should be fine. Longer, I would at least try some RG58, or RG8.
    Now, if you get an external antenna, you can connect a connector to match the antenna. Just do a search and you will find many antennas that can fill your needs. (Search terms "wifi antenna SMA, or whatever connector you want to use)
    Michael
  1. PCI Extension and Graphics Card Hook UP
    By alienjj in forum General Hardware Discussion
    Last Post: 03-14-2005, 11:10 PM
  2. PCI or USB notebook PC card adapter exist?
    By kandyman676 in forum General Hardware Discussion
    Last Post: 01-22-2005, 12:57 AM
  3. FS: Black 13.3" TFT LCD and PCI controller card CHEAP
    By Riverdale in forum Classified Archive
    Last Post: 12-09-2004, 11:07 PM
  4. PCI Graphics or Sound card - EPIA M10000
    By ZimZimmer in forum Newbie
    Last Post: 08-05-2004, 11:02 PM
  5. 5.6" LCD, PCI TV/Radio, 7.1 sound card, Sony amp & more
    By eatyummypuppies in forum Classified Archive
    Last Post: 06-29-2004, 08:19 PM
