Results 11 to 20 of 22
Thread: PhoneControl and the Motorola V710 (CDMA)
  1. #11
    Apr 2005
    Quote Originally Posted by PDiddy
    So I wanted to hook up PhoneControl.net through Centrafuse with my v710. Is this a complete lost cause? What are my other options as far as getting bluetooth to be integrated within Centrafuse??
    Doesn't this mean it works??
    Configuration for Motorola V710 (CDMA)
  2. #12
    Apr 2005
    Quote Originally Posted by White Night
    brilliant post. check the configuration out. cut and paste it. this has been covered in the forums before too. i don't want to be "this guy", but i can't resist. , it's your friend.
  3. #13
    Apr 2005
    Quote Originally Posted by dirtylarry
    it works.
    Does this mean you've used phoncontrol.net with a v710? I'm just confirming because if it does, I'll probably go ahead and get a v710. I have a different phone at the moment but would switch if I knew someone had actually done it before.
  4. #14
    Feb 2004
    NYC
    is this a bad time to ask it if it would work for my Samsung i730?
  5. #15
    Apr 2005
    you need the firmware update, i hear verizon will do it for you, i did it myself. yes i've gotten it to work. it's not an ideal setup with phonecontrol, the quality isn't that good. there's an echo that won't go away, i don't know if it's phoco or the bluetooth connection. i haven't used phoco with it that much, i have the hs850 earpiece, and that works beautifully, i just pick up the phone to see who's calling. phoco is good in theory, and i'm sure many users here have had good results, but the v710 and phoco isn't a quality solution. i haven't tried the treo 650 from verizon, or the new e815, but the v710 isn't up to par with my anal perfectionist ways.
  6. #16
    Jun 2002
    Indiana
    Quote Originally Posted by Peoples
    i've got the e815 (just got it last night), and plan on getting this to work with phoco, no matter what it takes. The e815 is basically the same phone as the v710.....just nicer. Anyway sonicxtacy02 is right, i found people on howardforums who claim to have gotten everything working. There is a seem update on http://www.inetron.com/index.php?opt...electcat&cat=1
    and a bunch of files that i plan on using later. First i need my damn datacable, and escalade182 has it right now and hes 150 miles away.
    I just made the seem edits on my 815, but havent got to try out phonecontrol yet. Maybe i will find some time this weeend
  7. #17
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Let us know if yo get the e815 working
    It has full OBEX capability unlike the v710 so I have a feeling it will work
  8. #18
    Dec 2004
    I'm not sure what you guys mean. Everything that I have read from PhoCo is CDMA is NOT supported at all.
    Even with SuperDave's seem edits on HoFo I was under the impression it won't work at all regardless. Please let me know if someone can get this working. I don't wanna get the E815. I get the 710 for free from work so I'd like to keep this phone working and get it working in the carputer setup!
  9. #19
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    I think there is alot of confusion here. Does zorro post here anymore? He could clear it up
  10. #20
    Apr 2005
    pdiddy, let me clear this up for you
    you need the firmware update... yes i've gotten it to work. it's not an ideal setup with phonecontrol, the quality isn't that good. there's an echo that won't go away, i don't know if it's phoco or the bluetooth connection.
    it works with phoco.
