Using Windows as handsfree with Bluetooth Dongle and BT enabled phone
I'm try to use my CARPC with windows XP working for answer a call with bluetooth dongle and enabled bluetooth phone.
All works well I connect the phone before receive a call (Fast connect -> Audio Gateway -> myDevice). The problem is the connection doesn't stop itself when a call ends. It remain connected as long as I disconnect manually from phone or from PC.
I've tried to use Phone Control (I've bought it....) but the program runs slow on my epia sp13000, and I don't need to use all its features, so I need only an answer software that can disconnect an riconnect BT when needed.
Can anyone help me? Thanks.
