can anyone help me?
I'm try to use my CARPC with windows XP working for answer a call with bluetooth dongle and enabled bluetooth phone.
All works well I connect the phone before receive a call (Fast connect -> Audio Gateway -> myDevice). The problem is the connection doesn't stop itself when a call ends. It remain connected as long as I disconnect manually from phone or from PC.
I've tried to use Phone Control (I've bought it....) but the program runs slow on my epia sp13000, and I don't need to use all its features, so I need only an answer software that can disconnect an riconnect BT when needed.
Can anyone help me? Thanks.
can anyone help me?
Figure out what command needs to be send to your phone to hang up. Then make a program which will send it.
