Results 1 to 4 of 4
Thread: Need help with making my laptop Wireless
    Constant Bitrate JuMpMaN6235's Avatar
    Feb 2005
    ok, so i just purchased my first laptop, and i just set up a D-link wireless router ... installed it already and its all good. However when i go to set up a wireless connection in my laptop, its not working, heres what i did:
    Network connections -> double click "Wireless network connection" .....The box that pops up is empty, so i click on advanced, thw two boxes their are empty, so i click on add, enter all the info, then click on refresh, But nothing happens, it stays as a red X..... can anyone help me out?
    Constant Bitrate techeros's Avatar
    03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
    Carputer Planning |---------*|
    Overall Implementation |---------*-|
    (Stereo complete)
    Computer installed and working
    Jul 2005
    What type of a laptop is it (i.e. Dell, Gateway)
    I had the same problem with my laptop at first then I took the time to stare at the keyboard a little. Low and behold I found out that if you use the FUNCTION key and the F2 key (my has what looks like a capitol "A" with little signal marks on it -- or a wireless tower if you will) the laptop connected to my wireless router instantly and the dialog box came up showing what type of network I was connected to and the strength. I hope this helps you. If you have anymore questions feel free to throw them out there.
    Oct 2004
    I'm guessing either the wireless is turned off as mentioned above or drivers aren't installed or correct.... check hardware profiles to see if the wireless card is installed & active...
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 03:28 AM
  2. Laptop for carputer project
    By airborne_cookie in forum Newbie
    Last Post: 05-31-2005, 11:23 AM
  3. Replies: 47
    Last Post: 05-03-2005, 01:28 PM
  4. Put laptop drive in dash?
    By eblend in forum General Hardware Discussion
    Last Post: 04-30-2005, 03:55 PM
  5. Laptop and Inverter?
    By ecaandrew in forum Power Supplies
    Last Post: 10-21-2004, 08:46 AM
