Results 1 to 6 of 6
Thread: bluetooth connection question
    May 2005
    im trying to figure out if this can be done before i buy the phone, dongle, and headset
    I'm wondering if you can connect the pc and phone with the headset at the same time....
    I.E. voice control the pc with the headset and then still use it to take/make calls.
    im sure you cannot use them at the same EXACT time like control the pc WHILE on the phone.
    what is the ease of doing both?
    i dont want to install a microphone knowing that they are kinda crap in comparison. i've read that controling the pc with the bluetooth headset is fine and using the BT HS is fine as well, so im intrested in the intergration of intregrating the two
    thanks
    Jwu
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    only some phones can do this, sony ericcsons can.
    motorolas limit you to 1 bluetooth connection at a time
    PC Components:
    My work log
    Nov 2004
    NYC
    Not impossible, but definitely an exercise if you want to learn to be patient. You'd have to actively connect and disconnect the bluetooth connection when alternating between the phone and PC from the headset.
    May 2005
    i think i lack the patience to even contemplate the process .... <--- joke
    two different BT headsets? <---- coolest kid on the block
    "not only do i have a pc in mycar but i have TWO BT headsets.... top that shizzle
    hahaha
    thanks guys
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    FYI: the Nokia 6230 can not manage more than one BT connection at a time.
    so shop carefuly for the phone.
    •Micke
    Low Bitrate rmjjensen's Avatar
    Oct 2003
    New Jersey
    yeah it depends on the phone. My Motorola V600 only supports one at a time ...arg - so the computer wins over headset.
  1. X10 remote and bluetooth problem
    By liquid_smoke in forum Input Devices
    Last Post: 02-27-2008, 05:51 PM
  2. Please Help! Widcomm 4 Bluetooth problems...
    By shmartyn in forum Wireless Communications
    Last Post: 07-28-2007, 06:09 PM
  3. Bluetooth connection issues
    By flaVius in forum Wireless Communications
    Last Post: 07-15-2005, 12:22 AM
  4. Lilliput drivers do not install with bluetooth
    By ryguy in forum LCD/Display
    Last Post: 06-12-2004, 10:52 AM
